FSJ tie rod anti-roll bushing
Some of the full size jeeps used an elastomeric bushing under the tie rod ends to prevent the tie rod from rolling as much.  It used to be something guys used to help make the inverted-T steering more responsive.
Does anyone remember what the P/N was? I believe it was a dealer only part too.
19 hours ago, ghetdjc320 said:
https://www.ruffstuffspecialties.com/R1768.html
They have a few varieties last I checked
Not those.  Those go on the drag link end at the tie rod/drag link interface.
The ones from the OEM, assuming I'm not suffering from the Mandela effect, went between the tie rod ends and the steering knuckle and stopped the tie rod from being able to roll.  They aren't an insert inside the tie rod either, but rather a bushing that just got sandwiched outside of the grease boot.  Or so I recall it, but our memories aren't real soooo...
5 hours ago, oleskool said:
Tie rod or draglink, doesn't matter.  They can be used in both spots.  I run them on my 1 ton swapped jeep with hydro assist to keep my tierod from flopping around under pressure.  Works just fine.
The FSJ part or the RuffStuff part?
