72cut Posted July 31, 2022 Share Posted July 31, 2022 Just brought home first Comanche, 87 pioneer, seven foot bed, auto, bucket seats. Couple questions, I do not see a fill neck on the radiator, doesn’t seem to have conventional radiator with fill neck on top. It does have plastic reservoir, passenger side of truck. What is the deal with this set up? Also, when I turn on right blinker both blinkers come on, no tail lights. Left blinker works fine. Sorry for the rookie questions, just starting to learn this thing. Also, the rear bed light now seems to stay on. More questions to come, please be patient. Thank you in advance for your time Link to comment Share on other sites More sharing options...
Muncher Posted July 31, 2022 Share Posted July 31, 2022 It's a pressurized system so no cap. Buy a normal radiator and a overflow bottle and you can convert to open Link to comment Share on other sites More sharing options...
Pete M Posted July 31, 2022 Share Posted July 31, 2022 the sockets are notorious for going bad so pull the bulbs and check inside for issues. do any of the rear lights work? if not, check the condition of the grounding wire behind the drivers side taillight. Link to comment Share on other sites More sharing options...
72cut Posted July 31, 2022 Author Share Posted July 31, 2022 Would a later model radiator from Xj work? Thanks all for reply. Only lights in back that work is left blinker. Actually haven’t checked brake lights yet. Like I said when I try right blinker both lights blink Link to comment Share on other sites More sharing options...
Pete M Posted July 31, 2022 Share Posted July 31, 2022 yes. I installed a later radiator and kept the rest of the pressurized system with no issues. if you haven't read it yet: Link to comment Share on other sites More sharing options...
cruiser54 Posted July 31, 2022 Share Posted July 31, 2022 First chance you get, go to www.cruiser54.com and complete Tips 1 through 5. Tips 1 and 2 covers a couple potential ground/lighting issues. Link to comment Share on other sites More sharing options...
72cut Posted August 26, 2022 Author Share Posted August 26, 2022 Ok thanks Link to comment Share on other sites More sharing options...
gogmorgo Posted August 26, 2022 Share Posted August 26, 2022 I wouldn't bother converting your cooling system unless there's something wrong with it. The closed system you have is less tolerant of leaks than the newer open system, and can be more problematic to burp all the air out of the system, but if there's no issues there isn't much sense in fixing what isn't broke. Most vehicles use a closed cooling system anymore because they're slightly more effective with the larger quantity of coolant in the system. Multi-filament bulbs coming on strangely often means the ground is bad so the circuit then seeks a ground via the other filament's circuit. It's also not unheard of to have a single-filament bulb mistakenly shoved into a dual-filament socket which can cause similar issues. If you're pulling bulbs to check, consult this thread if you're pulling bulbs out to make sure you've got the correct bulb in the socket. Link to comment Share on other sites More sharing options...
72cut Posted August 27, 2022 Author Share Posted August 27, 2022 Thanks all Link to comment Share on other sites More sharing options...
