Gojira94 Posted April 16, 2025 Author Share Posted April 16, 2025 3 minutes ago, Eagle_SX4 said: I found out this weekend that my horns only work when the key is on. Yeah, I was surprised when I read that in the electrical manual. Most cars from that era the horn wasn't 12V switched. Go figure. Link to comment Share on other sites More sharing options...
Gojira94 Posted April 17, 2025 Author Share Posted April 17, 2025 Off work from job 2 at 10PM, back on C100 TLC. LF turn signal now working. Conditioned all the female pins. A1 was slightly boogered. Took a little time with all pins on both sides, hoping my other issues can only benefit from the effort. Link to comment Share on other sites More sharing options...
Gojira94 Posted April 18, 2025 Author Share Posted April 18, 2025 Tall boy shifter stick from a TJ. I kinda like it. In first it sits at 3:00 from the wheel about 4" away. The tall AX15 shift tower IS from a TJ so it's a shorter throw already. XJ/ MJ shifter on the TJ shift tower: Link to comment Share on other sites More sharing options...
Gojira94 Posted April 20, 2025 Author Share Posted April 20, 2025 Started the day with another fuel pump replacement, found a NOS Bosch 69302 turbine pump. Went on to getting it up to temp and bleeding the cooling system. Link to comment Share on other sites More sharing options...
Gojira94 Posted April 30, 2025 Author Share Posted April 30, 2025 Carpet is in. I started the trimming at the front, just a little at a time until it lined up with the molded areas left and right. Then the sills, and rear last. I added a layer of 1/2" jute to all the areas the carpet didn't come with. Still have to install the rear corner trim/ seat belts and rear panel/ upper trim. And work the headliner in there while I'm at it. Really need to vacuum before I go any further lol. Link to comment Share on other sites More sharing options...
JeffK Posted May 2, 2025 Share Posted May 2, 2025 On 4/30/2025 at 10:43 AM, Gojira94 said: Carpet is in. I started the trimming at the front, just a little at a time until it lined up with the molded areas left and right. Then the sills, and rear last. I added a layer of 1/2" jute to all the areas the carpet didn't come with. Still have to install the rear corner trim/ seat belts and rear panel/ upper trim. And work the headliner in there while I'm at it. Really need to vacuum before I go any further lol. Looks good. Link to comment Share on other sites More sharing options...
Gojira94 Posted May 4, 2025 Author Share Posted May 4, 2025 On 5/2/2025 at 7:42 PM, JeffK said: Looks good. Thank you, sir! Your build is coming along very nicely as well. My dad is in Linville and he said to bring the MJ up when it's roadworthy. We might could meet up in WS for a side by side red 87 MJs pic sometime. Link to comment Share on other sites More sharing options...
Gojira94 Posted May 6, 2025 Author Share Posted May 6, 2025 Header panel stripped, cleaned and reassembled. O'Reilly-mixed Colorado Red in a rattle can worked pretty well to put some color back on it. It was pretty beat up. There's a deep enough crack above the Jeep logo that's going to have me looking for another header panel at some point but it's fine for now. The 10-slot grille is long gone but I don't mind the look of the 8. Link to comment Share on other sites More sharing options...
JeffK Posted May 6, 2025 Share Posted May 6, 2025 On 5/4/2025 at 10:44 AM, Gojira94 said: Thank you, sir! Your build is coming along very nicely as well. My dad is in Linville and he said to bring the MJ up when it's roadworthy. We might could meet up in WS for a side by side red 87 MJs pic sometime. We'll do that Link to comment Share on other sites More sharing options...
Gojira94 Posted May 9, 2025 Author Share Posted May 9, 2025 Header panel is on, all lights work (yay). Bumper needs to be adjusted up and tightened, lower valance needs a clean before going back on. Interior is complete except for headliner, bench seat and visors, which hopefully I can knock out tomorrow. Doors will be their own thing, side-project. The regulators need some maintenance and cleaning. Door cards are in great shape. In the next week, I'll be onward to rear suspension. Also need to get those 33s mounted on the steelies ASAP. Link to comment Share on other sites More sharing options...
Gojira94 Posted May 12, 2025 Author Share Posted May 12, 2025 Seat brackets cleaned up and painted. Spent some time with the Bissell Green Machine on the seat fabric and it came pretty darned clean. Bumper is adjusted and secured tightly now. Link to comment Share on other sites More sharing options...
Gojira94 Posted May 25, 2025 Author Share Posted May 25, 2025 She's sitting on her 33s now. Rear still isn't lifted but tackling that soon. Trying to completely finish the interior before moving on. Throttle body from Leigh Performance Machine is on, having issues getting the adapted TPS up to range. Right now it's adjusted maxed out at 10% idle / 85% WOT. Haven't run it yet, but will today. I don't know if the bored throttle body's idle set screw is moved during machining or not, might have to ping Jeff for more info on that. I don't want to pull the TB and mess with it if I can avoid creating another issue. Trying to get 3 variables to line up- determine set screw ideal position, TPS happy, and IAC counts NOT maxed or bottomed out to compensate. Link to comment Share on other sites More sharing options...
neohic Posted May 25, 2025 Share Posted May 25, 2025 Such a great looking truck! Been following this since the beginning and it’s awesome to see it all coming together. Well done! Link to comment Share on other sites More sharing options...
Gojira94 Posted May 25, 2025 Author Share Posted May 25, 2025 7 minutes ago, neohic said: Such a great looking truck! Been following this since the beginning and it’s awesome to see it all coming together. Well done! Thank you, thank you! There's still quite a few things to get squared away but she'll be on (and off) the road this summer for sure! Link to comment Share on other sites More sharing options...
Gojira94 Posted May 26, 2025 Author Share Posted May 26, 2025 it’s going into closed loop, O2 is working. Runs fine with TPS at 10% base. But… I’d like to see idle RPMs a tad higher. I read somewhere for a Renix manual anywhere from 650-800 is fine. I think I will adjust the base idle screw a hair. That’ll get me closer to 750 and probably raise the IAC counts a bit. I can only guess what that is, surprised the REM doesn’t pull and display that. I’m used to tuning GM stuff and IAC counts are a core indicator of a number of things, especially getting bigger cams to idle/ low speed off-idle without surge. EDIT: I take that back, REM does have an IAC indicator. However, Renix ECU only tells if it's moving one way or the other. ("<128 / >128"). I'll have to look at that again, but I'd expect it to be still and not moving up or down (stable at whatever counts it has at idle). IMG_0106.mp4 Link to comment Share on other sites More sharing options...
Gojira94 Posted May 26, 2025 Author Share Posted May 26, 2025 Passenger side regulator had dropped its receiver tube and there was no way I was going to get it back on the barbed end without pulling it. A little heat to soften it and I got it back on there. Followed instantly with ice to shrink and bond it as best as possible. I pulled the other one and greased both with synthetic grease. I don't know if that's a no-no, but the difference is amazing. Before they were both loud and very stiff. The ideal fastener to reinstall them would be stainless or yellow zinc M7-1.0 x 10mm ~or~ 9/32" x 1/2" but good luck finding those without having to wait a day or two at Fastenal or Amazon. Next best is 1/4"-20 x 1/2." With either nylon locking nut or prevailing torque nut on the back. The original rivets spin when you drill them, so you have to hold the back side of them with pliers while you drill. The nut to release the glass is 18mm. There's a wave washer under it. Link to comment Share on other sites More sharing options...
Gojira94 Posted May 26, 2025 Author Share Posted May 26, 2025 Passenger side regulator and both new door locks in. Missing half the regulator fastener hardware for the driver's door, but I'll pick that up from job #2 at 5:00. Taking the driver's door lock out, I noticed the short rod attached to it was disconnected from the latch assembly and there was electrical tape around it. And... the one at the lock cylinder was also taped and partially destroyed. Fortunately, I had a couple compatible rod clips left over from door work on my C1500 a couple years ago. All back together and works like it should. Passenger door, ready for panel: This is the lock cylinder kit I used: Link to comment Share on other sites More sharing options...
Gojira94 Posted June 2, 2025 Author Share Posted June 2, 2025 Doors finished. Link to comment Share on other sites More sharing options...
Gojira94 Posted June 2, 2025 Author Share Posted June 2, 2025 Front brakes installed. This is a PowerStop kit for 1999.5 XJ with cast rotors. Had to make a run to the boneyard for banjo bolts. Snagged a pair from a 97 V8 ZJ and another from an 06 Grand Cherokee. Exactly the same bolts all the way back to 91 apparently. Hoses are from Autozone - 777848 and 777849, 22" OAL. Pulling apart the rear brakes today on lunch break from job #1. Link to comment Share on other sites More sharing options...
Gojira94 Posted June 4, 2025 Author Share Posted June 4, 2025 D35 (non c-clip) is out. It needs carrier bearings and axle bearing kit. Pinion bearings and seal have been replaced not too long before I got the truck. Preload is good, bearings are smooth and seal is in good shape with no leaks. Axle splines are straight, axles look good for what they are. Running what I got until something else presents itself. Rear brakes aren't awful, but I have all new hardware and shoes anyway. And an opportunity to clean and re-paint the backing plates. Link to comment Share on other sites More sharing options...
Gojira94 Posted June 9, 2025 Author Share Posted June 9, 2025 Only update from the weekend- D35 housing is cleaned up. Base coat of Por-15 topcoat, followed by undercoating. Inner tube seals are on the way, carrier is at my machinist in Raleigh getting new bearings. Axle bearing kits may take another week to show up. I plan to have the housing back in SOA with the new leafs (leaves?) this week, with just the axles to go.Then I can take measurements for the rear driveshaft. Link to comment Share on other sites More sharing options...
Gojira94 Posted June 10, 2025 Author Share Posted June 10, 2025 In a holding pattern for the most part. Got the rear brakes blown apart so I can clean and paint the backing plates. Doing a little cleanup, I noticed this on one of the carrier bearing races. The carrier didn't have any discernible side-side play when I pulled it but there was obviously no preload, hence the decision to replace the bearings. Glad I didn't roll the dice and just run it. It'd have burned up good in no time... Link to comment Share on other sites More sharing options...
Gojira94 Posted June 16, 2025 Author Share Posted June 16, 2025 Science... Axle tube seals... Leaf springs installed (General 97-555). I picked up a cheap set of Chevy drop shackles for the moment so I can work on settling the springs. The temporary shackles will net 1.5" lift. If 5.5" SOA, this will make 7" give or take. Front is 6.5-6.75" right now. Something adjustable/ boomerang after that. Link to comment Share on other sites More sharing options...
Gojira94 Posted June 22, 2025 Author Share Posted June 22, 2025 SOA is in. The temporary shackles I put on showed way too high in the back far beyond what it'll settle. So I threw the original shackles back on. I'll need a 24+" rear brake hose to accommodate full droop. And the axle vent tube is 6-7" too short as well. Wheel stud installer broke on the 3rd stud... I'd hoped to get it all back together yesterday. Working on Volvos again today, so it'll have to wait a day or two. Link to comment Share on other sites More sharing options...
Gojira94 Posted July 1, 2025 Author Share Posted July 1, 2025 Longer wheel studs in, shocks mounted, all rear brake hardware staged and ready for assembly. Link to comment Share on other sites More sharing options...
