July 2022-The Wonton Manche
Build Thread-
Year/Model - 91 Pioneer
Drivetrain- Stock 4.0, AW4 and NP231. 07 Superduty Dana 60 front with Artec truss and full hydro mount, Barne4wd ORI mounts and Artec control arm mounts. Barnes4wd weld on high steer arms. 07 Sterling 10.5 rear with Motobilt diff cover, Ruffstuff u-bolt eliminator perches and shock mounts. 4.10 gears in both axles.
Cooling- Stock MJ radiator, PSC power steering cooler and auxillary transmission cooler with fan.
Electrical/Ignition- Battery moved to the rear and new cables ran.
Suspension/Steering- 3 Link front with Clayton Offroad crossmember. 14" ORI's in the front. Rear is SOA with stock springs on ubolt eliminator perches. PSC full hydraulic steering with PSC ram. PSC steering pump. Beyond percise orbital. Solid 7075 aluminum links from Wide Open Design, 2.5" lowers and 2" upper.
95899FC2-B737-4295-8CCC-2729E6954D8D.jpeg.d0b691a095875a66dd0629fe449c45cc.jpegC0FEEEC9-5423-4BEA-9868-FA2B912B4422.jpeg.04fde71d6cad972f784138b473bf82aa.jpeg0453ACC4-2644-47B2-B125-6C0A0F38FCF9.jpeg.9b51601fb8a598473dc4df437174271a.jpeg
Interior- PRP daily driver seats with cheap three point seat belts for now. Winter's shifter. Transmission temp gauge. Nifty Shifter Jr. transmission controller. Upgraded gauges from dummy lights.
Brakes- Stock superduty rotors, pads and calipers. WJ master cylinder and brake booster. Stainless steel braided hose to the axles, then hardlines out to flex hose on the calipers.
Lighting- Cheap Amazon special LED headlights. LED gauge lights and dome lights.
Exterior- Lund visor. Custom Coleman cooler battery box. Cut fenders to fit tires. Rock sliders need to be welded on. Need to build a rear bumper still.
Wheel & Tires- Pro Comp Xtreme wheels 17x9 with 4.75" backspacing. 40x13.50R17 Mickey Thompson Baja Boss.
Misc- Barnes4wd outside the frame trackbar mount. DOM trackbar and heims. Wide Open Design aluminum tie rods for the full hydro steering. Offroad Anonymous tiedown hooks front and rear. Barne4wd ORI towers.
Best MJ story- I had an MJ when I was in college and blew up the 4.0 that was in it. I held on to it for a bit and sold it like an idiot. Well I had a YJ and the a TJ. I sold the TJ to fund this project because I wanted something different than the typical Wranglers you see on the trails. So after two years of grinding on this thing it is ready for it's maiden voyage and I couldn't be more happier.
01A55FFD-754F-47BC-9952-9C2352B69690.jpeg.3f813d16f16fa65562fb9ca3562fdbc7.jpeg177CC046-C104-44D3-92F2-2F3EB47DB3C6.jpeg.cc1cf12f9c7987c99a8f768c6c252a0a.jpeg
CC is Awesome! Why? I love all the information that is on this forum. Plus it is awesome to see all the people thatlove these little trucks as much as I do.
Mission accomplished!   :L:   That's one hell of a trail rig!  :applause:
  • 3 months later...
  • 4 months later...
