marcus pop Posted June 28, 2022 Share Posted June 28, 2022 I'm tryna take out the air box and put in a simple spectre air intake but i dunno what to do with the rest if the randome vacuum hoses (not including the main one that connects to the valve cover). what do i do Link to comment Share on other sites More sharing options...
75sv1 Posted June 28, 2022 Share Posted June 28, 2022 Its been a while since I messed with those hose for the RENIX. Two options. First, just put one of those hot rod breather filters in the front hole of the valve cover. Other is to route the front cover hose to the fitting on the air filter tube, between the filter and the TB. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 28, 2022 Share Posted June 28, 2022 Why do you want to convert from a cold air intake to a hot air intake? Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 29, 2022 Share Posted June 29, 2022 11 hours ago, cruiser54 said: Why do you want to convert from a cold air intake to a hot air intake? Agreed. Is there an aftermarket setup that draws air from outside the engine bay? Link to comment Share on other sites More sharing options...
motownXJdad Posted July 3, 2022 Share Posted July 3, 2022 On 6/28/2022 at 8:18 PM, pizzaman09 said: Agreed. Is there an aftermarket setup that draws air from outside the engine bay? this is the best, cheapest XJ 4.0 cold air kit ive seen. its about 35 bucks total cost and all your vaccum lines stay put. i have all the parts needed purchased off Ebay, eventually it will be on here on my project 10BEARS build thread. Link to comment Share on other sites More sharing options...
Pete M Posted July 7, 2022 Share Posted July 7, 2022 the stock assembly is not all that bad. keeps things quiet and sucks in cold air. Link to comment Share on other sites More sharing options...
