Rick Jeep Posted June 18, 2022 Share Posted June 18, 2022 I have an 1986 Jeep Comanche with no brake lights. Old switch blew and I replaced it. Still no break lights. No Blown fuses all running lights work and all turn signals lights work. Any ideas? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted June 27, 2022 Share Posted June 27, 2022 Remove all the bulbs and check the contacts. Try reinstalling them one at a time and keep testing your lights. Also, lets see if @Pete M can move this to the modifications and repairs section. Link to comment Share on other sites More sharing options...
Pete M Posted June 27, 2022 Share Posted June 27, 2022 moved. now more eyes will see it. sorry I didn't spot it earlier. @Rick Jeep Link to comment Share on other sites More sharing options...
Ωhm Posted June 27, 2022 Share Posted June 27, 2022 Do the Hazards work? If not, double check the hazard/stop fuse. Link to comment Share on other sites More sharing options...
saveevryjp1998 Posted June 27, 2022 Share Posted June 27, 2022 On 6/18/2022 at 2:13 PM, Rick Jeep said: I have an 1986 Jeep Comanche with no brake lights. Old switch blew and I replaced it. Still no break lights. No Blown fuses all running lights work and all turn signals lights work. Any ideas? I'd check around the back portion of your harness that connects tail to tail and plate light/hitch harness(if you have one). A short or ground out there could potentially cause just the brakes light to go out on a poor slice or bad connection. Link to comment Share on other sites More sharing options...
zomeizter Posted June 27, 2022 Share Posted June 27, 2022 Mine did this randomly for a bit, turned out to be a corroded brake/hazard fuse and dirty fuse socket, check this out closely. Link to comment Share on other sites More sharing options...
