CEThomas Posted November 25, 2007 Share Posted November 25, 2007 Well got the rear DS cut and went to install it and found problems. The angle is to much and the DS is hitting the T-case yoke and not allowing the DS to angle down enough to hook up to the 8.8 :headpop: Others have no problems, so not sure what is wrong. I took the grinder to it to see if I could grind off enough to clear :mad: Link to comment Share on other sites More sharing options...
Twisty Posted November 25, 2007 Share Posted November 25, 2007 What about putting the MJ on the ground, and not letting the suspension droop. This would be a temporary solution, because if it gets wheeled, then it could rub and break the yoke, or joint. Link to comment Share on other sites More sharing options...
CEThomas Posted November 25, 2007 Author Share Posted November 25, 2007 On the ground you can get it hooked up but a good bumb on the road on go wheeling and going to break something :cry: Need to come up with the the right fix :roll: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 25, 2007 Share Posted November 25, 2007 your shaft is too short...you have too much yoke exposed. just because you have the brown section of the yoke don't mean it can't run there...you see the shiny spot, it runs there. it SHOULD run farther down the slip yoke than that. that will give you more room...but it's not gonna be cheap to retube. you didn't have the shop do the measurements did you? if you did they'll have to do it for free or next to nothing. I can't think of another reason that it wouldn't work except maybe your pinion angle isn't set right :dunno: Link to comment Share on other sites More sharing options...
oldjeep Posted November 25, 2007 Share Posted November 25, 2007 Time for a slip yoke eliminator and a CV shaft. How much lift have you got? Link to comment Share on other sites More sharing options...
CEThomas Posted November 25, 2007 Author Share Posted November 25, 2007 Slip yoke is out for photo, it's at the same spot it ran for the first 78,000 in the XJ, so that is not it. Pinion angle is 5deg both at the t-case and axle. Anyway, In the photo where the axle end of theDS is is where it's free hanging. The DS is maxed out on angle and will not go down any lower to match up to the axle. I need the DS to angle down a lot more :eek: Link to comment Share on other sites More sharing options...
CEThomas Posted November 25, 2007 Author Share Posted November 25, 2007 Time for a slip yoke eliminator and a CV shaft. How much lift have you got? That is what I am thinking, unless a t-case drop would help. Have around 6.5" of lift. a Ford 8.8 SOA with 4x4 springs that have no sag. Link to comment Share on other sites More sharing options...
TNT Posted November 25, 2007 Share Posted November 25, 2007 Replace your slip yoke with a YJ yoke to fix the front. Image Not Found Link to comment Share on other sites More sharing options...
TNT Posted November 25, 2007 Share Posted November 25, 2007 Time for a slip yoke eliminator and a CV shaft. How much lift have you got? That is what I am thinking, unless a t-case drop would help. Have around 6.5" of lift. a Ford 8.8 SOA with 4x4 springs that have no sag. That looks like about 8"-9" of lift. The YJ yoke allows for a much more angle at the transfer case. Probably double what your stock yoke offers if not more. Link to comment Share on other sites More sharing options...
oldjeep Posted November 25, 2007 Share Posted November 25, 2007 With that much lift, an SYE and CV is about the only thing that's going to do it. Why drop the tcase when you've gone through all the work to get the belly up off the ground? Link to comment Share on other sites More sharing options...
TNT Posted November 25, 2007 Share Posted November 25, 2007 With that much lift, an SYE and CV is about the only thing that's going to do it. Why drop the tcase when you've gone through all the work to get the belly up off the ground? If his rear yoke doesn't bottom out at full flex he will be good to go. The YJ yoke allows for 25+ degrees of flex. I ran it on my XJ with 5.5" of lift and 7" of droop. I could have added about 10" more droop before it would bind up and that was with a shorter driveshaft. I ran it at a constant 15 degree operating angle with no problems. Link to comment Share on other sites More sharing options...
TNT Posted November 25, 2007 Share Posted November 25, 2007 A SYE is the best way to go, but it's not needed. A YJ yoke will work. A SYE does keep the driveshaft from hitting rocks as often and will allow for better driveline angles. It will also tip up the diff and that will sometimes cause pinion bearings to fail. Link to comment Share on other sites More sharing options...
oldjeep Posted November 25, 2007 Share Posted November 25, 2007 Jeez, if I'd known that YJ yokes were good for something I wouldn't have thrown so many away. :) On a YJ, they are completely useless for more than 2" of lift. Link to comment Share on other sites More sharing options...
CEThomas Posted November 25, 2007 Author Share Posted November 25, 2007 That looks like about 8"-9" of lift. The YJ yoke allows for a much more angle at the transfer case. Probably double what your stock yoke offers if not more. We did not check at the start of the project, but just went out and checked and it's 44 1/4" at the center of the rear opening. The other end is OK and turn it 90 deg and it clears on the DS side :roll: The JY would at least get me through till we can go SYE 8) Link to comment Share on other sites More sharing options...
TNT Posted November 25, 2007 Share Posted November 25, 2007 Jeez, if I'd known that YJ yokes were good for something I wouldn't have thrown so many away. :) On a YJ, they are completely useless for more than 2" of lift. You should have been selling them to XJ and MJ guys... :D Link to comment Share on other sites More sharing options...
pingpong Posted November 26, 2007 Share Posted November 26, 2007 Couple of things to consider. IIRC the 8.8 pinion sits a lil lower. There are a couple of options. The easiest would be to rotate your pinion up to about 7* or 8*. The other option is to change from the companion flange setup to a yoke style set up. I think that even if you change to the yoke you would still have to rotate the pinion though. Link to comment Share on other sites More sharing options...
Pete M Posted November 26, 2007 Share Posted November 26, 2007 Not sure if it'll help anything, but your driveshaft is on backwards. The rubber isolator should be down by the axle. Link to comment Share on other sites More sharing options...
CEThomas Posted November 26, 2007 Author Share Posted November 26, 2007 Couple of things to consider. IIRC the 8.8 pinion sits a lil lower. There are a couple of options. The easiest would be to rotate your pinion up to about 7* or 8*. The other option is to change from the companion flange setup to a yoke style set up. I think that even if you change to the yoke you would still have to rotate the pinion though. Not sure if 8* would be enough. In the photo below the DS is bottomed out on the T-case yoke. Buy the time I move the DS up is it's not hitting the yoke and turn the DS up to meet the DS will be more then 8* :dunno: Link to comment Share on other sites More sharing options...
CEThomas Posted November 26, 2007 Author Share Posted November 26, 2007 Not sure if it'll help anything, but your driveshaft is on backwards. The rubber isolator should be down by the axle. Could not rember which way went down :oops: Put it that way so the DS weights would have more protection. Link to comment Share on other sites More sharing options...
TNT Posted November 26, 2007 Share Posted November 26, 2007 Here's a picture of how much flex my YJ yoke has.... 28 degrees With a 30" shaft it has 18" of down travel at bind with the yoke at 0 degrees. Image Not Found Link to comment Share on other sites More sharing options...
CEThomas Posted November 26, 2007 Author Share Posted November 26, 2007 Thanks, Anyone have a YJ yoke :D Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 26, 2007 Share Posted November 26, 2007 I still think that yoke is sticking out too far anyways. I don't think the one in my 89 stuck out that far... but, a YJ yoke would most definitely help. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 26, 2007 Share Posted November 26, 2007 Yeah, I have a new one. What's the measurement on your existing yoke from the center of the u-joint cap to the end of the slip shaft? This one is a Spicer unit and measures 5-7/8". Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
CEThomas Posted November 26, 2007 Author Share Posted November 26, 2007 I still think that yoke is sticking out too far anyways. I don't think the one in my 89 stuck out that far... but, a YJ yoke would most definitely help. It matches up tp the other 3 yokes we have. But then it's also about 2-3" longer then the 89 yoke :chillin: Link to comment Share on other sites More sharing options...
CEThomas Posted November 26, 2007 Author Share Posted November 26, 2007 Yeah, I have a new one. What's the measurement on your existing yoke from the center of the u-joint cap to the end of the slip shaft? This one is a Spicer unit and measures 5-7/8". Image Not Found Image Not Found It's 5 7/8" but looking for something used / cheep as we may have to go with the SYE if it will not work. Link to comment Share on other sites More sharing options...
