Part # for coolant temp sensor (in intake)?
The part listed at NAPA ECH TS5018 was not correct. The thread size does not match. Mine is 1/2-18 and the TS5018 has a larger diameter threaded portion (I neglected to measure it before returning it).
NAPA also lists TEM 207805 which looks similar but might be the correct part. It would take a week to get in stock.
O'Reilly's said that their system suggest a part that interchanged with the ECH TS018, so it is probably not the right size either.
Any advice?
It began with a misunderstanding. I ordered sending units for my coolant temp (gauge) and oil pressure from NAPA for a full cluster upgrade. When I showed up to get the parts they had included this in my order for some reason. I figured for $30 I'd go ahead and replace it even though I had no reason to suspect it was bad. Classic mistake.
Next rookie mistake was cutting the wires so that I could use a socket insted of wrench to remove it.
I am pretty new to renix and do not know how the ECU uses or does not use info from this sensor. Perhaps it is not really needed other than to plug the hole in the intake?
I am not finding it when searching for "intake air temperature sensor".
24 minutes ago, eaglescout526 said:
You can’t find those new anymore. Someone at some point found another style but has a different plug that you’ll have to swap out. I’d have to find the post. I have an IAT laying around that came from one of the 2.5L manifolds I have.
Of course. I'll solder and heat shrink the connector back onto mine.
