TonyJ Posted November 21, 2021 Share Posted November 21, 2021 I have a 1987 jeep comanche can I swap the motor with a 1993 motor? Link to comment Share on other sites More sharing options...
olddude Posted November 21, 2021 Share Posted November 21, 2021 55 minutes ago, TonyJ said: I have a 1987 jeep comanche can I swap the motor with a 1993 motor? Are they both the same type motor? 6 holes or 4 holes? Link to comment Share on other sites More sharing options...
Pete M Posted November 21, 2021 Share Posted November 21, 2021 just the block? or the entire fuel/wire harness too? Link to comment Share on other sites More sharing options...
89 MJ Posted November 21, 2021 Share Posted November 21, 2021 Here is some info if you have a 4.0 and are keeping it Renix. Link to comment Share on other sites More sharing options...
TonyJ Posted November 21, 2021 Author Share Posted November 21, 2021 2 hours ago, olddude said: Are they both the same type motor? 6 holes or 4 holes? They are both the same type motor. 4 holes. Link to comment Share on other sites More sharing options...
87MJTIM Posted November 21, 2021 Share Posted November 21, 2021 I put a 93 XJ 4.0 in a CJ7. I pulled the engine wiring harness and the ECU to do the install. On the CJ forums, there is a rule "Five Wires to Fire." That means that just five wires from the "new" engine wiring will connect to the "old" wiring. I don't know the number of wires for the Renix system. You most likely would want just about everything from the 93 to install in your 87. Link to comment Share on other sites More sharing options...
cruiser54 Posted November 21, 2021 Share Posted November 21, 2021 Okay. So both 4 cylinder motors. YES. Swap as if a long block, using the intake, exhaust, flywheel from your truck on the 93 engine. Link to comment Share on other sites More sharing options...
