Project “Tomahawk”
  • Replies 842
1 hour ago, Comanche SS said:
Looks great, did you get behind those engine mounts??
Also, don't forget to do your first scratch, so it can be over with and you can move on mentally lol
Of course! The body color starts at the lower control arm mounts. That’s where it transitions to raptor liner.
Front axle completely disassembled. Managed to completely clean out the axle tubes, weld on new upper control arm mount and HD track bar mount. The brackets are from stinkyfab off-road and are very well made. Sanded the entire housing, primed and painted. Regear up next with arb then back under the truck. Moog control arm bushing and spicer ball joints installed. Sprayed the inside of the tubes with Eastwood internal frame coating.
Looks great, how did you clean the tubes so well?
Should sleeve the axle while its at this point, will be as robust as can be at that point
I made a tool that I could attach to the drill and run a scotch bright pad on. Then used a 2.25 wire wheel on an extension. Finished with mineral spirits soaked rags I’d push through with more pipe. Turned out great. I’d prefer not to add any extra weight from sleeving. Trying to keep unsprung weight to a minimum
Dana 30’s are quick but finicky to setup gears on. Got the pinion depth acceptable on the second try but took 7 attempts to get the bearing preload correct. Anyways, here are the specs: carrier backlash .009, carrier prepoad .015 (added .015 to the shims after getting to zero play), pinion rotating torque 15inlbs with no carrier installed, pinion depth shim stack .070 including the oil slinger. I could have gone maybe .001-.002 deeper on the pinion but the pattern is within spec.
19 minutes ago, ghetdjc320 said:
Dana 30’s are quick but finicky to setup gears on. Got the pinion depth acceptable on the second try but took 7 attempts to get the bearing preload correct. Anyways, here are the specs: carrier preload 9 thousandths, 15 thousandths preload, pinion rotating torque 15inlbs with no carrier installed, pinion depth shim stack 70 thousandths including the oil slinger.
Kinda glad to read this. I thought it was just my inexperience with gears that made my d30 difficult. Took me twice as long as the 44, which I did first. Not looking forward to the one I have left to do yet in the cj.
This differential had been rebuilt at some point and it was done very poorly. It’s unfortunate since I didn’t have reliable numbers to start from. I suspect many people get away with less than ideal settings in the front axle as they see less torque and use than the rear.
Np242 gate swapped. There’s no difference in throw, it’s just the placement of the “gate” that makes the difference. Also added some tube seals. Need to get creative with the grease zert as I have inner C braces but I packed them with green grease already. The tubes were so full of scale, rust and mud that I really wanted a better solution. The plastic dust caps help but not as much as I’d like.
Will be curious of your take on those tube seals, more often than not its been found they just trap moisture and dirt inside without a way for it to escape.
But...those people arent as meticulous and caring as you are with this build, so your results may be better.
All in all, it looks to really be coming together. Whats next?
Yeah I went back and forth on what to do with the axle tubes. My use case is probably a bit different than most who get these. This is mostly a street truck but due to the heavy weather we tend to get along with the salt spray, I thought they’d be a good idea. Plus having coated the inside of the tubes makes me feel better about running them.
Next up is finishing the firewall accessories then move to engine/tranny/tcase install. Lots of little mods along the way.
Of note, when using the WK2 calipers, they use a 10mm banjo bolt. The YJ lines I have use a 3/8 banjo bolt so I filed them out until the 10mm banjo bolt fit perfectly. Turned out very nice
Very nice, so sounds like it should go together rather quickly, all parts acquired just the labor of the build left?
Can't wait to see this truck on the road.
Pretty much. Just need driveshafts, a battery, exhaust and some bunch list items. The final task will be body work. The next major project will be electrical.
Is it too much to ask that the aftermarket spend an extra few minutes on engineering the products they think are worth their weight in gold?? Quick draw could have just made a small 45* flat slope on their ax15 bell housing just like the oem jeep ax15 bell housings have. That would have provided almost universal clearance. And maybe spend a few more pennys to upgrade the insta-rust bell housing bolts they send along to something coated in say… zinc? :dunno:
I had already marked where I’d like more clearance on the bell housing with the engine positioned. I cutout that area and made a small plate to cover it. Then I seam sealed the back and riveted it to the bell housing. It shaved off about 3/4” in the area that was interfering. Doesn’t look like much in the pictures but the hole is about 2x5”. I ground down the sourrounding areas to provide a more “flush” mating surface. Primed and painted the bell housing with VHT cast aluminum paint.
41 minutes ago, Comanche SS said:
Wow, still pretty close even with the clearances made
Yeah, my transmission is just on a jack stand at the moment and is sitting a bit too high. But I also moved the engine back to the middle alignment hole. I think it’s going to be spot on with about 1/2” of clearance or a tad more when in final position
Just a few build notes on this swap so far:
The LS2 (c6 corvette) water pump is a nice swap and saves a lot of room between the engine and radiator.
I'm also quite pleased with the 3/8npt to 1/8npt reducer that allows me to run the stock jeep gauge sender for temp. The stock threads in the head are metric and about the size of an m10 bolt. There are adapters that fit the threads and give you a 1/8npt female side but do not allow the sensor probe to fit properly. Drilling and tapping to 3/8npt gives plenty of material for the jeep sensor to thread into and actually allows the probe to reach the coolant stream.
Also upgraded to the LS2 ps puller which is a nice steel unit vs the plastic ls1 unit. the puller also has holes that allow you to access all the power steering pump bolts making removal much easier. I have noticed that the corvette parts do seem like top shelf components so ive tried to stick with all genuine GM corvette stuff as much as possible and tried to avoid as many custom parts under the hood as practical for easier servicing down the road.
1 hour ago, ghetdjc320 said:
Nice clearance all around here. The air intake is the tricky part
If you can rotate or replace that throttle body with a less intrusive style one, you can spin the PS resi, and run a 4'' intake tube around it like I did in my MJ
