Dana 35 gears
1988comanche
  On 8/30/2021 at 4:15 PM, 1988comanche said:
88 pioneer
Expand
That would be a non c-clip dana 35 if it’s the original axle. You’ll need parts from a 1989 or earlier axle then.
The non c clip style axle can use 4340 chromo steel shafts that even the 8.8 can’t use because of the c clip design. A set of 30 spline 4340 axle shaft, 30 spline arb (installed correctly) and a tnt truss with a Spicer HD cover and you’ve got one stout little axle. Chryo treat you R&P and you’ve got an axle that can handle 35’s all day long with more clearance than the 8.8 can dream of. Just a thought
