Engine bay sticker
I was looking into this before, and there's a lot of companies who will remake your emissions label... except they only sell to collision centers.  What's up with that?  Anyways, looks like we'll have to get someone on the forums to make em, and it doesn't help that there's some pretty big year-to-year changes with them, too!  If anyone does step up, I want one for 87!
50 minutes ago, eaglescout526 said:
I’d love one of those. The one in my bay is falling apart except it’s gotta be 2.5L though.
 If someone would send me one for 2.5  i'm more than certain the same place could make more.  The problem is every year is different on the labels and also different engines too . It's cheaper when you have a big run of them done instead of one for every year. And in that case, we need quite a bit of demand for them to make it worthwhile . I don't even remember what I spent for the ones I currently have, but for a little piece of paper is pretty expensive that I recall.
A picture of one? Mine isn’t perfect enough of an example to replicate unfortunately. I’m sure there would be a demand if we made it known everywhere.
Got the 88 4.0 finished. If someone can get printed then it should be good to go (You'll need PDF obviously). Or if enough people are interested, I can just order some of each year we get created and sell them.
Can someone look it over to verify accuracy? Mine is a little worn in a spot or 2.
If someone can get me a pic of the 87 4.0 I can alter to match.
Just now, PocketsEmptied said:
Got the 88 4.0 finished. If someone can get printed then it should be good to go.
I really should of gotten a better picture
2 minutes ago, Muncher said:
I have someone who could make them to but itd be my specific year. 87 4.0 5 speed
Can you get me photos like these? I need every detail. I don't believe the bottom portion changed, just the info.
 No, I pulled mine off and took it in. They touched it up in the places the letters were missing. Maybe somebody else can do it  with a picture.
Well I kinda already drilled through mine
I grabbed the photos from the old thread from @fiatslug87 for '89 & '90 and will work on those this weekend. A great example of exactly what kind of photos are needed for any decals.
10 hours ago, scaleless said:
Here's my '87.
Thanks for this. Can you verify the width is 9"? I know they changed in 90, but I only have measurements for '88 & '89. Did it not have the vacuum diagram on there? That blank space looks very odd. Also can you verify the top right code for the barcode? It looks the same for '87 as '88 but want to make sure.
I already took off for work, but I can definitely get those things for you this afternoon.  And maybe a clearer, brighter pic, too :D
As for the vacuum diagram, yeah it's missing.  Don't think it's there on any 87 I've seen. Maybe some other guys can confirm that its normally like that.
