1992 MJ wiper issues
Picked up my 1992 MJ last week and have given it more attention it has seen in years. Currently, I am trying to get the windshield wipers working correctly. I replaced the bushings in the linkage and swapped out the wiper motor for a new one. Unfortunately the wipers only move when they are switched to high and even then they struggle. I have since read that the wiper relay could be the problem. After looking under the dash it appears as though I am missing the relay. I have these two loose connections. Anyone able to confirm what they connect to?
If your truck has delay wipers it could be the wiper module.
Looks like this. It's attached with velcro to the back side of the lower dash trim. It's just below the steering column. If you have one you can plug to two connectors that go to it together.
Thank you for the part numbers! There are several available in the used market. Many of them are labeled as "XJ/YJ only." Will these also work with the MJ platform? Also, pictured below are the connectors under my dash. Do these just plug into the opposing ends of the relay? The pins don't appear as though they would match up to the relay box.
