Kickin’Chicken Posted June 22, 2021 Share Posted June 22, 2021 Critique at will! Link to comment Share on other sites More sharing options...
Kickin’Chicken Posted June 22, 2021 Author Share Posted June 22, 2021 Halfway home. Link to comment Share on other sites More sharing options...
Kickin’Chicken Posted June 22, 2021 Author Share Posted June 22, 2021 Link to comment Share on other sites More sharing options...
russel730 Posted June 22, 2021 Share Posted June 22, 2021 Any advice? I've been meaning to do this for a while and will have some time coming up. I'm novice at soldering but have been taking the time to practice. Link to comment Share on other sites More sharing options...
Kickin’Chicken Posted June 22, 2021 Author Share Posted June 22, 2021 42 minutes ago, russel730 said: Any advice? I've been meaning to do this for a while and will have some time coming up. I'm novice at soldering but have been taking the time to practice. I simply strip the wires back a half inch or more then twist them together tightly. Then I melt a little solder on top of the twisted union and - after it cools - wrap it tightly with electrical tape. Some prefer shrink wrap but tape has always worked fine for me. Know this: there are two sides of the connector, in my opinion. The left side has 10 wires and the right has 13. The left side wires all easily match up except for an orange wire mates to a grey wire. The right side has two identical colored tan wires. Be careful to take care of those first. After those are done you can cut all the remaining wires off in one whack. They all match up. Here those two tan/brown wires are: Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 22, 2021 Share Posted June 22, 2021 1 hour ago, russel730 said: Any advice? One wire at a time. Use heat shrink. There are additional factory ground splines outside of the C101, solder those also. Link to comment Share on other sites More sharing options...
scaleless Posted June 23, 2021 Share Posted June 23, 2021 Definitely use heat shrink, specifically the kind with glue on the inside. Not only is electrical tape much more of a hassle, but it also does not seal the joints against moisture, which leads to corrosion. As for the joint itself, I prefer to tin both sides and simply overlap them. It significantly reduces the bulk of the joint over twisting them together, but definitely isn't strong if poorly-soldered. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 23, 2021 Share Posted June 23, 2021 Click the link below. Even has video!! PS...I've lost 35 pounds since the video was filmed...... Link to comment Share on other sites More sharing options...
Torq_Shep Posted June 23, 2021 Share Posted June 23, 2021 4 minutes ago, cruiser54 said: Click the link below. Even has video!! PS...I've lost 35 pounds since the video was filmed...... Hell yeah! Congrats! That is a pretty big accomplishment! Link to comment Share on other sites More sharing options...
