tow mirror location
Here’s a pic of mine, they were on the truck when I purchased it so I have no idea how they decided the mounting location. They are pretty much perfect for me. Black and chrome are same mirrors just painted. I’d get some measurements, but truck is currently at a shop getting a heart and lung transplant.
  • 1 month later...
Have you ever been inside your doors?  Wondering if the brace is in there.  Any chance you could pull me some measurements from the edge of the door and down from the window?  Just don't wanna drill holes and my brackets not line up.
Pete I have concerns with where the brace locates in the door and if I will be able to drill the holes from the inside out.  But I haven't been in the doors to look since I got my tow mirrors.
it's been a few years since I took one apart that had the braces.  :dunno:  but where there's a will, there's a way :D
I should have my truck back from the shop doing my trans rebuild in a few days and will get the measurements for you then.
  • 6 months later...
Only the doors that had tow mirrors have the inner brace for mirrors. The tow mirrors bolt into the brace which have a welded nut. I've had heeps where I've found them filled over and repainted running normal mirrors. I wondered if all AMC doors had them built in initially and were just installed on all Mjs and Xjs until they were gone. I'm not sure. One thing is certain though, if you have the brace and no hole, drill out the bottom center hole what can be reached from inside door. Then use the hole for measuring. Realistically you could simply just make your own brace and toss in whatever you want. Finding solid factory mj/xj tow mirrors not rusted out internally in the Midwest won't be easy if your that focused on factory setup.
I have the door braces and mirrors. Just not sure where they bolt in or where to drill holes for the mirror.
On 2/18/2022 at 8:38 AM, coheed said:
These are measurements I took of the mounting holes from my trucks factory tow mirrors. I hope these are helpful
The measurements are correct. One set is pulled off of the front of the door and the other is from the front of the door handle. I measured everything 1000 times and drilled a small pilot hole. Installed the brace and shined a flashlight through to make sure I was lined up. After confirming location it was on to the step bit and install the mirrors. Pretty straightforward. Finished product pics are in my build thread. They will be coming back off to get painted in near future.
  • 4 weeks later...
  • 4 weeks later...
  • 2 months later...
26 minutes ago, Pete M said:
it's a piece that goes from the top to the bottom of the door to take the stress off the sheetmetal.
Oh, that looks impressive. Looks like it bolts down from the bottom and a couple of rivets in the center to hold it there.
Assuming these aren't to be found anywhere, I'll have to thing of a way to reinforce it.
