1989 jeep mj eliminator 4wd
XJ doors will fit. Be sure to drop your truck in the registry if it isn't there already. Is it a LWB? If it is, it isn't an Eliminator. This is a hard angle to tell, IMHO.
12 minutes ago, Jesse J said:
I can't wait to build some half doors out of xj doors this fall so I have them next year. it will be fun on a bun
thats  good idea because ill have to sacrifice my speakers if i get tube doors so i might find a 89 xj and try it lemme know how it goes and tips or ideas
22 minutes ago, ghetdjc320 said:
The drivers side kick panel is a tough location for a speaker due to the e brake being there. You could go with some 4x6 in the lower dash trim though.
I am swapping my e brake pedal for a hand one eventually
you can pop off the panel behind the door and below the seatbelt there is a about 5-6 in hole could run new wires to there and tun them up into the dash my ebrake don't work but its a stick haha
