88mjsally Posted April 26, 2021 Share Posted April 26, 2021 Bought this truck about a month ago after it had a dash fire. I’ve pretty much collected all the parts to put it back together so I’ll be posting that on here. The plan is probably to sell it after I put it back together since I really need a bigger truck to haul home projects. As fun as it is to have a fleet of comanches, they can’t really tow a car trailer safely Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 26, 2021 Share Posted April 26, 2021 sell it add to your funds. Much appreciated that tour saving it for someone to enjoy. looks like a solid truck. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 26, 2021 Share Posted April 26, 2021 Took a bit to convince ya but I think you’ll make a nice running MJ for someone to enjoy. Link to comment Share on other sites More sharing options...
88mjsally Posted January 24, 2022 Author Share Posted January 24, 2022 Well it’s been a while but this truck is all back together and runs and drives again. I originally planned to flip it but now I’m going to drive it to work. Just need to fix the water leaks in the cab, put the plastics back in it, put the new tires on and a few more things before I can start driving it Link to comment Share on other sites More sharing options...
88mjsally Posted January 24, 2022 Author Share Posted January 24, 2022 Got a full cluster in it yesterday which I thought would be hard since it’s a column shift but it ended up being really easy. I’ll try to get more pics of the inside later since it has a different seat in it now Link to comment Share on other sites More sharing options...
88mjsally Posted January 30, 2022 Author Share Posted January 30, 2022 Here’s some interior pics of how it looks currently. Need to fix a water leak, finish the headliner and put the interior panels back in it. I did get the fuel gauge wiring today thanks to a new Bosch pump I had and a used sending unit. The one in the truck came from an HO xj so it read backwards. Also swapped the fuel filter and it seems to crank better and the pump isnt loud like the old one Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 31, 2022 Share Posted January 31, 2022 Sweetness. that water leak from the cracked windshield..? Link to comment Share on other sites More sharing options...
88mjsally Posted January 31, 2022 Author Share Posted January 31, 2022 New tires and turbines are on today! Little smaller than what I normally buy but they’ll be good on the interstate driving to work. Much better than the steel wheels and bald tires Link to comment Share on other sites More sharing options...
88mjsally Posted January 31, 2022 Author Share Posted January 31, 2022 Most of the stripes are gone along with the paint…. Probably going to either paint the bottom part of the truck black or look into respraying the whole truck before too long Link to comment Share on other sites More sharing options...
scguy Posted February 1, 2022 Share Posted February 1, 2022 Coming along nicely! Should be a great commuter Link to comment Share on other sites More sharing options...
88mjsally Posted February 17, 2022 Author Share Posted February 17, 2022 Well it’s registered and insured now. Just needs a windshield and my dad decided to start painting the roof so it’s 2 tone at the moment. I’m having an issue with the trans at the moment so I need to figure that out tomorrow. I’m leaning towards it being the TCU since both the ones I tried have been next to fires and it doesn’t want to go out of 1st gear Link to comment Share on other sites More sharing options...
88mjsally Posted March 1, 2022 Author Share Posted March 1, 2022 Transmission still is acting up and honestly it’s about to become a parts truck like I originally planned. I’ve cleaned all the grounds, changed the tps (still can’t get voltage on the trans side), tried 4 different tcms, refreshed all the connectors, verified the resistance is good on the solenoids and changed the speed sensor. It shifts now after changing the speed sensor but shifts at 4k rpm. The tps still doesn’t give any voltage on the trans side no matter how it’s adjusted. The fire probably damaged some wire somewhere even though I didn’t see any heat damage in the engine bay around the harness Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 2, 2022 Share Posted March 2, 2022 Trace the tps wire back to it then I gather... Hows the fluid look? Drop the pan on the trans at all? Link to comment Share on other sites More sharing options...
88mjsally Posted March 2, 2022 Author Share Posted March 2, 2022 On 3/2/2022 at 12:48 AM, MiNi Beast said: Trace the tps wire back to it then I gather... Hows the fluid look? Drop the pan on the trans at all? Expand Fluid looks good and is full. I haven’t dropped the pan and haven’t really seen a need to since the solenoids tested good Link to comment Share on other sites More sharing options...
scguy Posted March 2, 2022 Share Posted March 2, 2022 I'd suggest running a new wire from the TPS to the TCM. Link to comment Share on other sites More sharing options...
88mjsally Posted March 5, 2022 Author Share Posted March 5, 2022 Well I finally got it figured out. When the truck had the fire the TCU plug got melted so I spliced in a new one. Turned out there were 3 wires that had a twin of the same color and I got the two red ones mixed up so I didn’t have power to the tps. Swapped those wires and it shifts nice and smooth now just like it’s supposed to. Now just for an alignment, glass and a paint job for the roof Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 5, 2022 Share Posted March 5, 2022 Well sweetness. thats a good step in the process. Link to comment Share on other sites More sharing options...
Pete M Posted March 9, 2022 Share Posted March 9, 2022 Link to comment Share on other sites More sharing options...
88mjsally Posted March 10, 2022 Author Share Posted March 10, 2022 Well todays wrenching didn’t exactly go to plan. Started just changing the water pump and ended up changing the power steering pump and pressure hose because they were leaking and I had new ones. Then I tried to take the thermostat housing off and the upper bolt was seized to it so now I need a new one of those. Also need a new power steering pump pulley and a new grill… So it might go back together this weekend when the parts come in Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 10, 2022 Share Posted March 10, 2022 Definitely gots corrosion. Well peace of mind once all back together with fresh parts. Little by little. Link to comment Share on other sites More sharing options...
88mjsally Posted March 11, 2022 Author Share Posted March 11, 2022 New power steering pulley and thermostat housing are in. Put it all back together for the most part. Just need to go get heater hose tomorrow to finish the open cooling swap Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 12, 2022 Share Posted March 12, 2022 don't forget the bolt in the header.. Link to comment Share on other sites More sharing options...
88mjsally Posted March 12, 2022 Author Share Posted March 12, 2022 On 3/12/2022 at 5:50 PM, MiNi Beast said: don't forget the bolt in the header.. Expand It’s broke off in the head and doesn’t leak so it’ll be fine. It’s been like that ever since I got it Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 12, 2022 Share Posted March 12, 2022 I had one on those once. Actually one of the power steering bolts right now. Link to comment Share on other sites More sharing options...
Pete M Posted March 12, 2022 Share Posted March 12, 2022 if it's good, it's good Link to comment Share on other sites More sharing options...
