89 MJ Posted January 25, 2021 Share Posted January 25, 2021 What help videos should be created for showing how to use features on this site? I have already done creating/editing a signature, editing a post, and uploading pictures. Are there any other videos that should be made? Link to comment Share on other sites More sharing options...
Dzimm Posted January 25, 2021 Share Posted January 25, 2021 How to use the search function would be a good one. Link to comment Share on other sites More sharing options...
89 MJ Posted January 25, 2021 Author Share Posted January 25, 2021 3 minutes ago, Dzimm said: How to use the search function would be a good one. It would. I'll see about coming up with a video for that one. Link to comment Share on other sites More sharing options...
Ωhm Posted January 25, 2021 Share Posted January 25, 2021 Using the feature to reuse a photo/video without taking away for your allotted storage space. Goto: Other Media (lower right corner of this responds box) Select "Insert existing attachment" If you name your photo/video with a easily remembered file name the search function works well. Link to comment Share on other sites More sharing options...
89 MJ Posted January 25, 2021 Author Share Posted January 25, 2021 33 minutes ago, Ωhm said: Using the feature to reuse a photo/video without taking away for your allotted storage space. Goto: Other Media (lower right corner of this responds box) Select "Insert existing attachment" If you name your photo/video with a easily remembered file name the search function works well. Interesting. I didn't even know that. I will be sure to experiment with that some and then create the video on it. Thank you! Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted January 26, 2021 Share Posted January 26, 2021 9 hours ago, 89 MJ said: 9 hours ago, Dzimm said: How to use the search function would be a good one. It would. I'll see about coming up with a video for that one. If you are already doing this I would recommend a small bit about using the "site:comancheclub.com *search string*" feature on google. I am more likely to use that than anything else. Even for things not comancheclub related, like limiting results to a certain journal, etc. Link to comment Share on other sites More sharing options...
89 MJ Posted January 26, 2021 Author Share Posted January 26, 2021 2 hours ago, JustEmptyEveryPocket said: If you are already doing this I would recommend a small bit about using the "site:comancheclub.com *search string*" feature on google. I am more likely to use that than anything else. Even for things not comancheclub related, like limiting results to a certain journal, etc. I can go that. Thanks for the idea! Link to comment Share on other sites More sharing options...
Minuit Posted January 26, 2021 Share Posted January 26, 2021 3 hours ago, JustEmptyEveryPocket said: If you are already doing this I would recommend a small bit about using the "site:comancheclub.com *search string*" feature on google. I am more likely to use that than anything else. Even for things not comancheclub related, like limiting results to a certain journal, etc. This 100%. Way too many people don't know about search operators, and the site:comancheclub.com trick on Google is usually more effective than the built in search on any given website anyway. You can also search for "exact phrases" or -subtract -words. You can also search for one thing | another (logical OR) https://moz.com/learn/seo/search-operators Link to comment Share on other sites More sharing options...
