You have buckets and you want to keep buckets? The seat brackets are MJ specific. Otherwise, 2 door XJ seats are very similar, they just have different brackets. @Pete M, please move this to tech.
I have bench and I want to put bucket in
Ok, any Comanche bucket seat (1986 to 1992) Will bolt right in, otherwise any Cherokee seat (1984-1994) will fit if you change the seat brackets. @krustyballer16 makes new seat brackets.
:yeahthat:
It's not a huge deal if the seats don't fold forward if you aren't going to drive the truck much, but that space is very valuable in my truck as I do drive my truck every day in the summer and I use just about all of the cab space that there is.
2 hours ago, schardein said:
Just be aware that MJ bucket seats and 2 door XJ bucket seats have the fold forward feature.  4 door XJ front seats do not fold forward.
...but the individual parts (frame, upholstery, foam, side bolsters) are all mix-and-match within the 1984-1994 time frame, so a 2-door XJ (or MJ) seat with destroyed upholstery can be combined with a 4 door XJ seat's good upholstery. Non-bolstered seats can be converted to bolstered seats as well.
Probably good to take the upholstery off a new-to-you seat and run it through the wash anyway. Who knows what kind of gross crap the previous owners subjected it to.
That's exactly what I did to end up with my buckets.  Seat frames from a 2dr XJ, headrests from another XJ, 2 upper fabrics and one lower from another, and the driver bottom from a 4th.
I used XJ seats in my MJ. They work great, they just don't fold forward.  I just get behind the seats from the other side of the truck. It's a minor pain, but not that bad to gain access behind the seat(s). But how often do I really need to get behind the seats?
