Dave Vig Posted January 8, 2021 Posted January 8, 2021 Can you guys please tell me what this part is exactly called? Is it a crank case breather assembly? Reason being is I need one plus the hose
JMO413 Posted January 8, 2021 Posted January 8, 2021 There should be a whole manifold setup there. https://www.amazon.com/dp/B000630DJO/ref=cm_sw_r_cp_apa_i_NR89Fb8WA6ZRT https://www.amazon.com/dp/B000630DJ4/ref=cm_sw_r_cp_apa_i_hS89FbB3DYFVT These two snap together. It should look like this.
JMO413 Posted January 8, 2021 Posted January 8, 2021 Just now, Dave Vig said: Thank you Welcome. Yours seems allot like mine when I first got it.
MiNi Beast Posted January 8, 2021 Posted January 8, 2021 my last engine had so much blow by i ran front hose over to a 1 liter bottle to catch the oil. then once half full after a day or two id just dump it back in. keep oil in it and it will stay running.
schardein Posted January 8, 2021 Posted January 8, 2021 Technically that's not the PCV valve, it is the fresh air intake for the crankcase ventilation system. That hose is hooked to the air cleaner where it draws clean filtered air into the engine. The Positive Crankcase Ventilation valve is the part stuck in the rear opening of the valve cover. It has a small metered orifice that is connected to a manifold vacuum source on the intake manifold. Engine vacuum draws crankcase gases out of the engine, and in turn fresh air is drawn in through the front hose. Excessive blowby could mean the metered orifice is plugged with carbon, sludge, dirt, etc and preventing the system from working. The crankcase pressure is then forcing gases and oil out the fresh air intake hose because it has nowhere else to go. Cleaning the rear metered orifice could help. Given the age of our trucks, the excessive blowby could also be caused by bad piston rings allowing combustion chamber pressure to escape into the crankcase. It's still a good idea to check the PCV orifice and clean it if necessary.
AZJeff Posted January 8, 2021 Posted January 8, 2021 The 4.0 crankcase ventilation system is properly called a CCV (controlled crankcase ventilation) system. And as others pointed out, it uses a metered orifice in the REAR hose on the valve cover to control the amount of crankcase vapors that are sucked into the intake manifold when the engine is running. when the engine gets old, this metered orifice can become restricted, and thus the normal draw of vapors from the crankcase is defeated. Once that happens, crankcase vapors blow out through the intake hose on the FRONT of the valve cover, and the engine gets coated in oil residue. It may also contribute to oil loss by other than burning, and thus it is wise to address a plugged CCV system in the way others have explained above.
