Rubikahn Posted December 3, 2020 Posted December 3, 2020 So I’m trying to remove a bench seat but the nuts are rusted and seized onto the the seat frame base on the floor. I looked underneath for bolts sticking out which I would cut off to release it, but the underneath is so rusted out I’m not seeing them. Is it possible to remove it without cutting up the frame?
Torq_Shep Posted December 3, 2020 Posted December 3, 2020 They are studs that are pressed or welded onto the frame. Your best bet is to cut them (or break them) from the top if you can't get them loose.
Torq_Shep Posted December 3, 2020 Posted December 3, 2020 The are on the outside lip of the unibody except the one (on both sides) that sits up higher than the others.
Rubikahn Posted December 3, 2020 Author Posted December 3, 2020 28 minutes ago, Torq_Shep said: The are on the outside lip of the unibody except the one (on both sides) that sits up higher than the others. Thank you, I’ll look underneath again to find them. I was able to get two of the nuts off the rear bracket mounting point that sit higher and on the outside closer to the doors. I’m assuming those are the ones I can’t get to from underneath?
Torq_Shep Posted December 3, 2020 Posted December 3, 2020 That should be correct IIRC. I can go look at my gutted comanche to confirm
Gubachoo Posted December 4, 2020 Posted December 4, 2020 8 hours ago, Rubikahn said: Thank you, I’ll look underneath again to find them. I was able to get two of the nuts off the rear bracket mounting point that sit higher and on the outside closer to the doors. I’m assuming those are the ones I can’t get to from underneath? You can't get to any of them from underneath, they are all pressed into the floorpan. Your best bet is to hammer a socket on and break them off then replace them once the seat is pulled up. You could put a bolt through the hole from underneath with a little work so you can take it back out but you can't get around having to break them off up above if they are seized. you can try to soak them with penetrant for a few days first to see if they loosen up, but it's more than likely you'll have to break them and replace them. Just did this last week.
Rubikahn Posted December 4, 2020 Author Posted December 4, 2020 29 minutes ago, Gubachoo said: You can't get to any of them from underneath, they are all pressed into the floorpan. Your best bet is to hammer a socket on and break them off then replace them once the seat is pulled up. You could put a bolt through the hole from underneath with a little work so you can take it back out but you can't get around having to break them off up above if they are seized. you can try to soak them with penetrant for a few days first to see if they loosen up, but it's more than likely you'll have to break them and replace them. Just did this last week. Ok, I’ll give that a try. Most of them are so rusted that the edges of the bolts have crumbled off.
Gubachoo Posted December 5, 2020 Posted December 5, 2020 23 hours ago, Rubikahn said: Ok, I’ll give that a try. Most of them are so rusted that the edges of the bolts have crumbled off. So I was wrong. Took another look while working on the truck today and it turns out there are lock nuts for the two front inbound studs underneath. They are 15mm and the stud is in a threaded insert spot welded into the frame. To get mine to break I hammered a 9/16 impact socket on the rusty nut and then broke it off once it was seated. Hope that helps, and good luck.
omega_rugal Posted December 5, 2020 Posted December 5, 2020 try a nut breaker, you can't get those from below
Cheapamanche Posted December 5, 2020 Posted December 5, 2020 16 hours ago, omega_rugal said: try a nut breaker, you can't get those from below ^^^ This
grouch Posted December 6, 2020 Posted December 6, 2020 Pick up a can of Rust buster oil (it's in a little black bottle) or a little coca cola should eat the rust or as above a Nut Buster. Just don't force it...get a bigger hammer.
