Cheapamanche
Everything posted by Cheapamanche
^^^ This
Do I NEED another MJ???
Cheapamanche replied to kaidenlem's topic in MJ Tech: Modification and Repairs
YES..... Now what does your post say? Oh crap, nope, nevermind. Just read the post. Pass. I would try to buy the canopy though. -
Avoid ShopJeepParts.com
Cheapamanche replied to big66440's topic in MJ Tech: Modification and Repairs
Noted -
I'm totally stumped (mech oil gauge)
Cheapamanche replied to Cheapamanche's topic in MJ Tech: Modification and Repairs
Original filter was a WIX, second was a red Purolator. I didn't even attempt to bleed the line. I have heard this before but when I kill the engine the oil bleeds back into the engine. won't this introduce air again? -
Thank you guys for the reply. I did a little experiment last night. I drained about 1 quart of oil and added a quart of Marvel in its place. I took it for a ride and the pressure never went over 70. I think that the penzoil 10w30 is not suited very well for my winter enviroment. I think I'm going to switch to a 5w30 for winter. -
Is there a relief valve in the oil pump that could be sticking? -
Sporadic dip or surge in idle
Cheapamanche replied to PhilisDiller's topic in MJ Tech: Modification and Repairs
I am a firm believer in doing what benefits me in the long run. Thats usually the smart choice. -
If you think that at any time down the road youbwill swap to the flex pipe manifold, I would just weld it. No sense in buying new just to replace it as soon as you get the chance. Save some money in the meantime. Whats a couple extra days waiting to weld them. -
I recently installed a mechanical oil pressure gauge in my 88 comanche 4.0 and I don't understand what my oil pressure is doing. My oil pressure is really good at idle, it's about 40 psi cold but with the slightest touch of the throttle or just incresing cruising rpm to about 1700 it climbs to about 80, hangs for about 1 seconds and then drops back down to about 50-60. Sometimes it spikes OVER 100 and then drops, almost like it builds up pressure and then something gives and blows off pressure. In a previous post I though it was a blown head gasket because I was losing coolant but it looks like its just a bad overflow tank cap. I also pulled the spark plugs and none of them look washed out or wet or oily. Does anybody have any ideas? I'm usually pretty good at researching and figuring things out but the ONLY search results I get for 4.0 oil pressure problems are either, "just replace the sender" or "it only needs 10psi for every 1000 rpm" I'm stumped guys, please help. I'm using 10w30 penzoil platinum. I also changed the oil filter once thinking it was a bad oil filter. Didnt help.
Oil pressure fluctuations, mechanical gauge
Well I have more signs of a head gasket failure. My overflow resevour was under pressure about 12 hours after driving it last. I took the cap off and pffff. I still have not had a chance to compression test as I have a 2 week old new baby in my life and I have been so dang busy. I'm so bummed because about a week ago I finally figured out why my truck was so jerky at low speed. I ripped out all the nasty split loom and found some ground shorts that were causing voltage fluctuations! It finally runs so smooth and now this... One day at a time. I'll have to wait until after Christmas to fix it. I have 4 kids that I am buying presents for this year! -
Thanks for your reply. I have not checked my plugs in about 6 month. Thats a great point. I'll check them. I just noticed I have a very slow coolant leak that I have not been able to source yet. Is it possible that I have a head gasket leak that could be causing the oil pressure issue? I have no signs of coolant in my oil. -
I swapped out my oil filter just in case the bypass valve had faild and still same issue. Today at idle it was sitting at 70psi on the mechanical gauge.... Again I have no blowby when I take the valve cover cap off but there is some white mist... I will try exchanging the mechanical gauge and see if something is wrong with it. Any other ideas? -
I was running Valvoline full synth before, same weight. Never had this issue. Not sure if the oil fluctuations have been going on for a while though. I just put the mechanical gauge on this last oil change. -
Hello everyone, its been a while. I will be a thorough as I can. Well winter has come upon us so I decided to do an oil change and a few other winter prep things. This time I went with penzoil 10w30 platinum synth with a bottle of zddp for good measure. Wix oil filter. After doing the oil change I started noticing that sender was going bad so I ibstalled a mechanical one. Oil pressure is 60-65 cold and about 40-45 hot. I thought awesone.... at first. Recently I made a trip into town and noticed that I had a lifter tick suddenly and my oil pressure on the mechanical gauge was at about 70. I let it sit for about 45 minutes and it was back to normal. I started boticing this will happen once every 15 trips in the truck now... I do see that the oil leak at the oil filter adapter has started leaking much more significantly than before the oil change and I have a lot more oil build up on top of my valve. Could this be caused by a bad oil filter? I have no blow by when I take the valve cover cap off but I do have a lot of white mist. Thanks guys. 1988 Comanche, 4.0, BA 10/5, 160,000 miles
Starter relay blown fusible link
Will do thanks -
What year, engine, all that stuff.
Aftermarket Fuse Block
Cheapamanche replied to TheBearken's topic in MJ Tech: Modification and Repairs
Good advise. Saving money is good. Better yet why not just get all 4s? Again, I need to learn how to solder.... And I need a new fuse block too haha -
True, I just like the excuse for a cigar.
In fact, I know it's part of my issue. If I jiggle the wires to my driver blinker it shorts out. -
I looked for this harness. I couldn't find it. I pulled the headlamp out and still no luck. You have been a tremendous help! Got the 4 hole injectors in. They fixed my leak and my stumbling idle. -
No nothing that causes alarm. Aside from my driver side front running light always being on and my front blinkers sometimes working, I'm just going to let good enough be for the time being. I don't have the time or funds to fix anything right now. It's my work truck and I need it Monday through friday and with three young daughters they take up my weekend time right now. I just discovered my injectors are leaking and this needs to take top priority at the moment. I don't need a fire. -
Geezer probably. The last owner, garaged for 15 years, was a high school student. The C101 is very clean and so are the ecu connectors. They look brand new clean. If you really want to see them or suspect them I can send some pics tomorrow. I have the bbq going right now. Hungry kids. -
I pulled the relay and it does not prime still. Does that mean the short is before the relay? -
Nevermind I see it. Try the smoke trick. Take a cigar or cigarette and blow it into manifold vacuum and see where it goes.
Have you tried blowing smoke into the engine to see if it leaks out anywhere? Does this seem like a sensor issue, maybe MAP sensor? I don't see a vacuum line hooked up to the map. Should the 86 have one?
