Back wall of the interior cab
How much weight are you planning on putting in it?
It's sheet metal so it has its limits but it's a small space so I wouldn't expect you would have much that will fit back there.
You could always build a box that rests on the floor and just attaches to the wall to keep from tipping when you fold the seat forward.  Then you could put a bunch of weight in without worrying about it.  Even if it just had some legs rather than fitting to the floor, it might be a better design.
21 minutes ago, Pete M said:
I bolted a 3/4 sheet of plywood to the rear steel wall and covered it with speakerbox carpet.  lets me screw brackets and whatnot to it :L:
How did you bolt it to rear wall? I'm looking into doing something similar.
drilled holes in the upper corners of where the plywood would go, inserted bolts, tightened them.  I probably added some goo to seal it up too.
Do you have any pictures of it? Becuase i have the raised carpeted peice in the back of my truck and would like to try to keep it looking like that
