5x5 bolt pattern with WJ swap
I am just spit balling here.
Would it be possible to convert front axle to 5x5 with wj unit bearing will doing the wj knuckle/brake swap?
I have read different information on the interwebs saying you can run wj knuckles and wj unit bearings and be fine (as in without welding the metal spacer), I also read you need the spacer to locate the ujoint with the ball joints but with the sapcer xj stub shaft is too short to get the axle nut installed.
Thoughts, opinions, comments?
Planning a future axle build and the wheels I want are 5x5
IIRC the underlying issue is centering the U joints
Pulled this tid bit from NAXJA
"The WJ hub has a flange offset of 2.11", the 01 Cherokee hub has a flange offset of 1.9 and the JK's is 1.9 as well. Assuming it has the same mounting lugs, the JK hub is the bolt pattern you want and the right flange offset. Note, though, that the JK uses a longer stub shaft and presumably it does so for a reason. It's either spline count, length thru the hub or length back from hub to U-joint or some combination and I'm not sure.
I'd be really curious to see you use the JK hub, but I think the easier method is going to be wheel adapters.
If you do pursue JK hubs, please post up results."
The JK uses a 30 spline outer even in the d30. So WJ knuckles and brakes with JK unit bearings and stub shafts? Interesting concept. I believe JK knuckles are also an option and if they are then that opens up the possibility of Reid knuckles... Someone please try this combo and post up the results!
Found on pirate. There went that idea
I measured a TJ and JK knuckle. The 3 bolt wheel bearing pattern has 4.10" bolt spacing on both but that is the only similarity. The JK has bigger calipers so different bolt hole spacing (5.4" vs 5.75"), and the JK ball joints are further apart then the TJs (8 5/8" vs 8 1/4"), so they will not swap.
The WJ knuckles bolt on to the JK axles which means that the JK knuckles bolt to TJ/XJ/YJ axles! I am starting to suspect that Vanco runs a RHD and LHD JK knuckle with Ford rotors and calipers. The lower ball joint should be replaced with the WJ/JK one for proper clearance but many don’t. I’ve been trying to crack the recipe for a “bolt-on” big brake kit for 90+ D30’s for a while now.
8 minutes ago, 75sv1 said:
I have done this swap on an XJ. WJ hubs to use WJ rims. Yes, the 1/4 spacer is still needed. I have run this setup about a year now.
But the question is using JK unit bearings instead of WJ ones. The stub shaft would need to be changed but otherwise it seems like a possible bolt in
I did search for a possible stub shaft to make the WJ bolt in. I could not find dimensions on stub shaft. It would need to be 1/4 shorter than the XJ's from center of the U-joint hole to the flange.
my JK knuckles don’t fit my XJ axles.
if I remember I’ll take pic so show the difference. The JK Cs are larger than the XJ Cs. I’m also remembering that the JK axles won’t fit into XJ hubs, and vice versa
long time back I mocked up WJ knuckle and WJ hub with a JK Moab.
i think it needed some spacers I used washer for, maybe that’s where a JKS spacer would come in.
40 minutes ago, 75sv1 said:
The other is that the JK hubs have 32 spline. The Xj and WJ are 27. So a hub shaft change.
The D44 JK uses 32 but the D30 uses 30 spline outers. Since the WJ knuckles swap to the JK and XJ axles then the JK knuckles should swap to XJ/MJ/YJ/TJ as well.
Here is an XJ knuckle on. JK D44. The C is larger and the upper ball joint isn’t fully seated.
https://colorado4wheel.com/images/1988_MJ/MJ221.jpg
1 hour ago, ghetdjc320 said:
Swapping the ball joint is required when doing the WJ knuckle swap also
I know. but look at the difference in size.
is this something you have done and know works? Lots of people don’t swap the ball joints when doing the WJ swaps on XJs. Doesn’t mean it’s right.
6 hours ago, saveevryjp1998 said:
So the answer seams to be yes and no. Also crickets on said mentioned kit. At this point I'm at a firm no. The wj setup is pretty sweet and from what I can already see at least around 1/2 less cost than jk. I hope that helps "steer" you in the right direction swampy.
The regular moog problem saver ball joints should take care of that issue. Or adjustable control arms. The interesting thing with the Reid knuckles is if they had the standard old d44 spindle mounts so we could swap to different bolt patterns easily. The stock brakes on a WJ are slightly better than the JK in both piston surface are and pad swept surface. I wish Reid still made the d30/44 TJ knuckles. It was a perfect way to swap in locking hubs, 6x5.5 wheel pattern, d154 calipers and any steering you want. Perfect complement for a rodeo/passport rear. I'm really trying to find out what knuckles would bolt on to a xj D30 and offer different caliper mounting/unit bearing options.
8 hours ago, saveevryjp1998 said:
Can you get a measurement between the knuckle ears for upper and lower ball joint holes on the JK knuckle. The wj lower ball joint must be swapped in the xj lower place for the swap to work with wj. I've done it. Supposedly guys say they haven't and it destroys the knuckle fairly quick which I'm guessing makes perfect sense because it obvious it shouldn't fit. I'm not sure if it's as obvious from your link though. It's been several years since I did it. I actually never finished it because I was hunting down low clearance zerk fittings which could easily bypass that hiccup but I wanted it my way and that's it. The truck ended up parted but I still have it. I'm about to start on it again though and a second 1 I picked up a month ago. I do have 1 more set of wj knuckles ready however I'm rather curious about jk brakes and rotors vs wj. I've never had the chance to see or study the difference if any to see which may be better. I do know the jk route, if it's even bolt on, will not be cheaper unless you have the parts for free. Yards want way too much for the newer stuff.
ya I can get a measurement. I have an XJ d30 here with knuckles off and the Jk d44 here with knuckles off.
I actually bought a new JK knuckle to complete my axle, I picked up an 8k mile JK d44 over ten years ago, but it was missing the knuckle, saw you can get aftermarket these days reasonably priced.
