Hi everyone, I purchased this 88 Comanche back in May 2020, and I already started doing lots of work to it. I'll start posting pictures from the beginning.
When I purchased the Jeep it already had he following:
4.5" long arm lyft
Ford 8.8 rear axle with disc brakes
4.56 gears
4.0 Renix engine
AX-15 transmission
NP-231 transfer case
33" x 12.5" x 15" tires
Things I've done so far:
_Gutted the interior, sanded away surface rust on the floor boards and roof, sprayed with rust reformer and paint
_Shampoo and extract carpets
_Added sound deadening
_Replaced door panels
_Installed new headliner
_Replaced seat belt buckles
_Replaced door seals
_Replaced steering wheel
_Fixed the horn
_New interior lights
_Added missing rear view mirror
_replaced door stops
_New vacuum hoses
_New throttle position sensor
_New heater core hoses
_New thermostat
_Coolant flush
_Added coolant reservoir tank
_New XJ thermostat housing with temp sensor
_Wired electric fan to come on automatically (it was wired with a switch by previous owner)
_Fixed tierod roll and alignment
_New front bumper (JCR)
_97+ XJ front end conversion
_LED headlights
_New BF Goodrich all-terrain tires 33" x 10.5" x 15"
_Painted diff covers black (didn't like the red)
_New side view mirrors
In the future I plan on
_Raptorliner paint job
_Replace door locks
_Restore Tail lights (I smoked them, but I don't like it)
_Fix reverse light issue (I don't have reverse lights)
On 8/23/2020 at 10:07 PM, jdog said:
Welcome,
Check your trans fuse in the fuse block for reverse lights
Thanks, I did check all the fuses when I first got the truck. It was converted from 2wd to 4x4 so maybe things were not plugged in properly. I'll have to investigate.
19 hours ago, Pete M said:
lookin' good! :L:   be sure to track down the rain leak that caused the floor rust.
Of course. There were two leaks, both from the rear glass and front windshield. Both have been sealed off :)
  • 4 months later...
looks great!  :L:   if you're looking to move on to the cab, be extra sure not to plug any of the drain holes in the rockers, or doors
