88MJ_99XJ
Everything posted by 88MJ_99XJ
88 MJ Pioneer Olympic Edition
88MJ_99XJ replied to 88MJ_99XJ's topic in Member Projects: Your Comanches
Of course. There were two leaks, both from the rear glass and front windshield. Both have been sealed off :) -
Thanks, I did check all the fuses when I first got the truck. It was converted from 2wd to 4x4 so maybe things were not plugged in properly. I'll have to investigate. -
I'm going to reserve a few posts so I can add pictures to the front page in the future. -
Hi everyone, I purchased this 88 Comanche back in May 2020, and I already started doing lots of work to it. I'll start posting pictures from the beginning. When I purchased the Jeep it already had he following: 4.5" long arm lyft Ford 8.8 rear axle with disc brakes 4.56 gears 4.0 Renix engine AX-15 transmission NP-231 transfer case 33" x 12.5" x 15" tires ----------------------------------------------------------- Things I've done so far: _Gutted the interior, sanded away surface rust on the floor boards and roof, sprayed with rust reformer and paint _Shampoo and extract carpets _Added sound deadening _Replaced door panels _Installed new headliner _Replaced seat belt buckles _Replaced door seals _Replaced steering wheel _Fixed the horn _New interior lights _Added missing rear view mirror _replaced door stops _New vacuum hoses _New throttle position sensor _New heater core hoses _New thermostat _Coolant flush _Added coolant reservoir tank _New XJ thermostat housing with temp sensor _Wired electric fan to come on automatically (it was wired with a switch by previous owner) _Fixed tierod roll and alignment _New front bumper (JCR) _97+ XJ front end conversion _LED headlights _New BF Goodrich all-terrain tires 33" x 10.5" x 15" _Painted diff covers black (didn't like the red) _New side view mirrors ------------------------------------------------- In the future I plan on _Raptorliner paint job _Replace door locks _Restore Tail lights (I smoked them, but I don't like it) _Fix reverse light issue (I don't have reverse lights)
