Had throw my old coil springs back in for the time being because PO said it had a specific lift height, and it was clearly not that. Anyways, I had to use my hi-lift jack on the front bumper to remove the last jack stand (long story), and those of use that have worked with hi-lifts, they can be hectic. So as I was letting her aggressively drop the truck back down to the ground, this fell down on the ground. How neat! This key is the only key I have that has the AMC logo, and i have no idea where it popped out of because my hands have been all over the underside of the front end.
37 minutes ago, DesertRat1991 said:
Thats neat!  Is the box magnetic?
Yes, it is magnetic and pretty neat. I don't even think the PO knew it was there either. I can't believe it didn't fall until now, because there was one incident where I got sucked into some black sand and it was a pretty hard bang and stop.
10 hours ago, MontanaManche said:
maybe if you keep shaking it you'll find even more!
No doubt! Ha, she definitely has more days full of shaking ahead of her.
