Oscar Posted August 9, 2020 Posted August 9, 2020 I did a cluster swap from lights to gauges and was wondering what wire I need to use for the temp sensor since the new one doesn’t plug in. I have a 2.5 motor
eaglescout526 Posted August 9, 2020 Posted August 9, 2020 What? The temp sender is at the rear of the head top side. There's two styles a sender and a sensor. Sensor is for the gauge which you need and it uses the same plug as the sender did. Should be a really easy swap to do but youll lose coolant. Did you buy the coolant temp sensor for the ECU that goes into the side of the manifold?
schardein Posted August 9, 2020 Posted August 9, 2020 The Temp Sensor changed to a design that used a specific connector sometime around 1993 (in the XJs, of course). Oscar, what year is your MJ? What year did the new cluster come from? What year for the sensor? Here are pics of a temp sensor connector from a 93 XJ. I have another one if you are interested in buying it and splicing it onto your existing wire. EDIT: THIS IS FOR A 4.0, I'M NOT SURE IF A 2.5 IS THE SAME.
Ωhm Posted August 9, 2020 Posted August 9, 2020 When LOGGED-IN. Go to upper right hand corner of screen. Click on Username. Click on Account Settings. Find and click on Signature. Add vehicle information here (YR, ENG, TRANS, etc, etc) then click on SAVE. This helps everyone. This information will be available every time you post.
Pete M Posted August 9, 2020 Posted August 9, 2020 26 minutes ago, Ωhm said: When LOGGED-IN. Go to upper right hand corner of screen. Click on Username. Click on Account Settings. Find and click on Signature. Add vehicle information here (YR, ENG, TRANS, etc, etc) then click on SAVE. This helps everyone. This information will be available every time you post. I just noticed you have nothing in your signature
Ωhm Posted August 9, 2020 Posted August 9, 2020 10 minutes ago, Pete M said: I just noticed you have nothing in your signature Good one on me.
JimBorecky Posted May 12, 2021 Posted May 12, 2021 On 8/9/2020 at 11:48 AM, schardein said: Here are pics of a temp sensor connector from a 93 XJ. I have another one if you are interested in buying it and splicing it onto your existing wire. Schardein. you don't happen to have a part number do you?
schardein Posted May 13, 2021 Posted May 13, 2021 18 hours ago, JimBorecky said: Schardein. you don't happen to have a part number do you? A part number for the connector? Sorry, I do not.
