Muncher Posted July 30, 2020 Share Posted July 30, 2020 So I'm trying to access the main computer behind the glove box to check if theres any torn wires or anything. How do i get the glove box apart to get back there? Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 30, 2020 Share Posted July 30, 2020 ECU or TCU? Either way theres nothing behind the glove box. The TCU is behind the lower dash panel BELOW the glovebox and the ECU is up above the gas pedal. Link to comment Share on other sites More sharing options...
Muncher Posted July 30, 2020 Author Share Posted July 30, 2020 2 minutes ago, eaglescout526 said: ECU or TCU? Either way theres nothing behind the glove box. The TCU is behind the lower dash panel BELOW the glovebox and the ECU is up above the gas pedal. Ohhh ok thank you that helps out alot. Is the tcu yellow or silver? Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 30, 2020 Share Posted July 30, 2020 TCU is a dull silver and has Asin on a red label with an AMC part number. Link to comment Share on other sites More sharing options...
Muncher Posted July 30, 2020 Author Share Posted July 30, 2020 Ok thank you.Ā Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 30, 2020 Share Posted July 30, 2020 Welcome! Link to comment Share on other sites More sharing options...
Muncher Posted August 2, 2020 Author Share Posted August 2, 2020 Ok so i was told one of the computers was under the glove box. But where is it? I have it stripped down to this and am not sure where it is. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 2, 2020 Share Posted August 2, 2020 Thats your air box for the AC and heater core. The lower dash panel you took off should have the trans computer if you have an auto. Otherwise the ECU is on the drivers side under the dash above the gas pedal.(in your case its stillĀ attached to the dash) Link to comment Share on other sites More sharing options...
jdog Posted August 2, 2020 Share Posted August 2, 2020 11 minutes ago, Muncher said: one of the computers was under the glove box nope, no computers there, would help if you said which module you are looking for Link to comment Share on other sites More sharing options...
Muncher Posted August 2, 2020 Author Share Posted August 2, 2020 17 minutes ago, eaglescout526 said: Thats your air box for the AC and heater core. The lower dash panel you took off should have the trans computer if you have an auto. Otherwise the ECU is on the drivers side under the dash above the gas pedal.(in your case its stillĀ attached to the dash) Ohh ok that makes since. I do have a 5 speed. The ecu is the silver one right? Also what is the small yellow box under the dash Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 2, 2020 Share Posted August 2, 2020 Small yellow one is my favorite. Cruise control. Link to comment Share on other sites More sharing options...
jdog Posted August 2, 2020 Share Posted August 2, 2020 Yes, the yellow one is cruise control Link to comment Share on other sites More sharing options...
Eagle Posted August 2, 2020 Share Posted August 2, 2020 1 hour ago, Muncher said: Ok so i was told one of the computers was under the glove box. But where is it? I have it stripped down to this and am not sure where it is. Ā Your signature says you have a 5-speed. There's no TCU (Transmission Control Unit) for a manual transmission. Your ECU (Engine Control Unit) is on the driver's side, above the gas pedal. Link to comment Share on other sites More sharing options...
Muncher Posted August 2, 2020 Author Share Posted August 2, 2020 39 minutes ago, eaglescout526 said: Small yellow one is my favorite. Cruise control. I can't tell if you're joking or I'm just stupidĀ Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 2, 2020 Share Posted August 2, 2020 1 minute ago, Muncher said: I can't tell if you're joking or I'm just stupidĀ Nope, not kidding. Kinda took up as the knowledgeable one for factory cruise. Link to comment Share on other sites More sharing options...
Muncher Posted August 2, 2020 Author Share Posted August 2, 2020 1 minute ago, eaglescout526 said: Nope, not kidding. Kinda took up as the knowledgeable one for factory cruise. Oh well ok then. I didnt know it had that or even how to use it in my jeep. Itd probably help if it ran tho Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 2, 2020 Share Posted August 2, 2020 Actually if everything is still intact and operates as it should, it should all work via the signal stalk. Link to comment Share on other sites More sharing options...
Muncher Posted August 2, 2020 Author Share Posted August 2, 2020 Just now, eaglescout526 said: Actually if everything is still intact and operates as it should, it should all work via the signal stalk. Oh well ill have to try it out once i get her runningĀ Link to comment Share on other sites More sharing options...
Gjeep Posted August 4, 2020 Share Posted August 4, 2020 You have a 5-speed truck - if you had an automatic there would be the silver transmission box (TCU) on the lower dash panel you pulled. The only other silver box Renix years which you have would be to the upper right of the steering column. This is the engine controller. The yellow box drivers side on the lower dash panel is the cruise control. Link to comment Share on other sites More sharing options...
