Rear Right Turn Signal
Hello all.
My MJ recently developed a condition in which the passanger side rear turn sign does not flash when I have the brake pedal pressed down.
I've cleaned the light harness connector near the airbox but the problem persists.
Does anyone know where the tail lights ground to the body? Is it the same location as the fuel pump ground?
Thanks a bunch!
3 hours ago, jdog said:
Does it flash if your not on the brakes, do the brake lights and running lights work? Stupid question what bulbs are in it
Brake and running lights work and the turn signals both work if I don't press down the brake pedal. When I press the brake pedal, the right turn signal does not flash.
I have 1107's (I think) in it. New-ish sylvania bulbs.
I'm not sure about this but its easy enough to try:
KEY OFF.
Depress brake pedal.
Using T/S SW set to RH side, can you turn OFF the RH rear bulbs?
Try same thing for the LH side.
KEY OFF.
Depress brake pedel.
Using T/S SW set to RH side, can you turn OFF the RH rear bulb?
Ok, so, key off, brake pedal depressed:
All 4 lights come on.
Turn signal to the right:
Turn signal to the left:
Only right hand side lights come on.
Brakes not pressed (key on):
Turn signal right: right hand side flashes
Left side flashing
The STOP/TURN circuit is a strange circuit. It has two (2) B+ feeds. 1.Brake SW B+ feed. 2.T/S flasher B+ feed. Each B+ feed is determined by the position of the T/S SW. You either have a faulty T/S SW or the Brake SW B+ feed is shorted to the RH side STOP/TURN circuit. I'll keep looking to see if there's anyway to prove out one or the other.
Holy smokes! Thanks a TON man! I really appreciate it!
Disconnect C156.
KEY OFF.
DO NOT depress brake pedel.
On the IP Harness side measure for continuity between C156_N and C156_P. If NO continuity exist suspect T/S SW, wires or connector on the steering column. If continuity does exist wires are shorted within the IP Harness.
5 hours ago, Ωhm said:
Disconnect C156.
KEY OFF.
Ok, so, with the key off (column locked, actually) I have no continuity between N and P on the IP side. I'll be replacing the multifunction switch either today or tomorrow.
