ZJ V8 steering
There are a few Grand Cherokee's at the pick-n-pull with the V8s in them. I have gotten mixed reports on if I can use, or need both parts (drag & tie bar)? What will I need to grab to be able to swap it over to my MJ. Just the drag link & tie rod, or stabilizer too? I will be replacing all the rod ends with new ones, so why not have the beefier set-up. Thanks, Rich
90 and earlier draglink has smaller diameter threads on the tre than 91+ (ZJ's are ofcourse all 91+ anyways) you definitely want the bigger tre's
I had a ZJ tierod and it appeared stout but bent silly with a mild hit. A friend told me to remember back to elementary school science class and that a solid rod doesn't have as much tensile strength (I'm sure somebody will correct me on that term) as a hollow rod....basically a 1.5" .250 DOM (your standard HD aftermarket tie-rod) is much stronger than the solid ZJ one, which is considerably stronger than the stock XJ one.
