tire size
I just installed 4.10's today. Running 32's with the Renix 4.0, auto. It didn't like overdrive before & now it rolls along nicely. Won't win a drag race but it's liveable.
I really wanted 4.56's, but I scored a free R&P from a friend's YJ that got 4.88's. Gotta love freebie's.
I consider the optimum combinations to be 4.10 gears for 31" tires, 4.56 for 32" tires, and 4.88 gears for 33" tires.
YMMV
Keep in mind that 31" tires with 3.73 gears is exactly the same final drive ratio as stock tires and stock 3.54 gearing. 4.10s with 33s is probably going to effectively be about the same as a stock setup.In other words, livable but hardly optimum.
Just checked my charts. In overdrive with the 4.10s you'll be turning 1965 engine RPM at 60 MPH. With stock 225/75R15 tires and an auto, 60 MPH is 1938 RPM. You'll be okay on the road, but you won't have a great crawl ratio without more gear.
