Trying to identify a couple of connectors in a 1989 dash harness
1989 Comanche harness.
Trying to track down what the circled connector is used for if anything. Passenger side bundled with courtesy light and door switch passenger side harness. Power antenna maybe?
Also this connector. In the drivers side bundle by the fusebox. Emissions timer maybe?
Not seeing these colors come up on the 1988 wiring diagrams I have.
Emissions timer is a pak con connector with three terminals inside. The top one could be a speaker plug, but power antenna goes directly to the radio and is usually only a one prong plug with a grey wire.
Not sure about the bottom.
I thought all the door pins did was ground the courtesy light circuit and the pre 91 door pins were only 2 pin? Why would it be 3 wires? I thought the pink wire on the top picture was the door switch as it is also on the courtesy light circuit shown?
