Ωhm Posted May 7, 2020 Share Posted May 7, 2020 I just want you to be safe. Vapors/static electricity are the danger. Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 2 minutes ago, Ωhm said: I just want you to be safe. Vapors/static electricity are the danger. Yessir. Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 But like I said, my only option currently is small jumper cables, and if you would like me to proceed, I'd need a little more idea of what exactly I'm doing. Where am I attaching to fuel pump? Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 7, 2020 Share Posted May 7, 2020 On the pump itself should be two prongs. If the clips are attached wrong, the pump will blow bubbles and if they are clipped on the other way, it pump the fuel. But one of the wires going to the pump should be black indicating ground. Link to comment Share on other sites More sharing options...
Ωhm Posted May 7, 2020 Share Posted May 7, 2020 5 minutes ago, SoCalManche said: But like I said, my only option currently is small jumper cables, and if you would like me to proceed, I'd need a little more idea of what exactly I'm doing. Where am I attaching to fuel pump? What I was looking for is to disconnect the fuel pump from the vehicle wiring and powering the pump right off of the battery. Even another battery would work. Hook plus to plus and neg to neg at the fuel pump connector. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 7, 2020 Share Posted May 7, 2020 What Ωhm said. Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 1 minute ago, Ωhm said: What I was looking for is to disconnect the fuel pump from the vehicle wiring and powering the pump right off of the battery. Even another battery would work. Hook plus to plus and neg to neg at the fuel pump connector. Okay, that's what I thought. Yes, I've done that test before and it fires right up. I will do it again. I was told in my thread about this a year ago that testing directly like that doesn't do anything. At least that's what was said. Link to comment Share on other sites More sharing options...
Ωhm Posted May 7, 2020 Share Posted May 7, 2020 In this set up once the pump is running, attempt to START vehicle. Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 30 minutes ago, Ωhm said: In this set up once the pump is running, attempt to START vehicle. Same thing occurs; Did not add fuel to TBI. Had someone else crank while I held the leads to my TJ's battery (disconnected from TJ, of course). She showed intermittent FIRING, not quite catching fully to gain full START. Same thing occurs if it is connected normally through the harness. Link to comment Share on other sites More sharing options...
Ωhm Posted May 7, 2020 Share Posted May 7, 2020 Good news to hear this testing went well, only it didn't solve anything. Do you own a timing light? Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 2 minutes ago, Ωhm said: Good news to hear this testing went well, only it didn't solve anything. Do you own a timing light? I do not. You think the timing is off? Link to comment Share on other sites More sharing options...
Ωhm Posted May 7, 2020 Share Posted May 7, 2020 No, not the timing. Somewhere I read you can hook up a timing light and look at the injector spray pattern while cranking the engine. May have to move pickup to different spark plug wires, but you should be able to see the spray pattern. Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 19 minutes ago, Ωhm said: May have to move pickup to different spark plug wires, but you should be able to see the spray pattern. Can you elaborate on this point? I'm not following. Link to comment Share on other sites More sharing options...
Ωhm Posted May 7, 2020 Share Posted May 7, 2020 12 minutes ago, SoCalManche said: Can you elaborate on this point? I'm not following. Hook up a timing light and point it down the TB. The strobe effect will freeze the spray pattern. Different spark plug wire (timing light pickup) will give different views. Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 Alright, I'll have to snag one tomorrow to check the spray pattern. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 7, 2020 Share Posted May 7, 2020 I still wonder if the fuel pump can put out but not enough pressure to keep up with the demand of the ECU and engine. Like yes we saw the pump can build the pressure but can it maintain that pressure when fuel is needed? Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 1 minute ago, eaglescout526 said: I still wonder if the fuel pump can put out but not enough pressure to keep up with the demand of the ECU and engine. Like yes we saw the pump can build the pressure but can it maintain that pressure when fuel is needed? I have a spare I can go hook up to see. Even so, only 4V at FP connector with KEY ON; 3-something V when cranking. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 7, 2020 Share Posted May 7, 2020 That just doesn't sound like enough voltage for anything. But even applying 12V directly to the pump itself yielded near firing of the engine. Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 19 minutes ago, eaglescout526 said: That just doesn't sound like enough voltage for anything. But even applying 12V directly to the pump itself yielded near firing of the engine. So basically applying 12V directly or 3-4V through harness yield same results, so pump may be bad? Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 7, 2020 Share Posted May 7, 2020 Yes and no, I would hold off on the pump thing until we get this fuel injector thing figured out but it could be the pump, but 3-4 volts still doesn't sound right unless that's all it really needs but if that was the case then why would they have put a ballast on the later years? Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 So here is a video of it starting, everything hooked back up to normal, with same pump. Looks like the ISA is working properly now? Idle shoots through the room now before dying. https://drive.google.com/open?id=14qRsMq6PkL9HlcRitcJSioziefSfxxFN Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 7, 2020 Share Posted May 7, 2020 Heyyyyy the ISA works!! I know that sound after shut down anywhere. I think we are moving away from the bad ECU idea. Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 11 minutes ago, eaglescout526 said: Heyyyyy the ISA works!! I know that sound after shut down anywhere. I think we are moving away from the bad ECU idea. So just terrible grounding on top of what was already terrible grounding. Lol Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 7, 2020 Share Posted May 7, 2020 Very well could've been. Still need to figure out this fuel problem. So pump constantly running with 12V applied and relay in place, it kinda wants to start but it acts like its not getting enough fuel to meet the demand of starting. Sound right? So I wonder if power loss is at that bulk head met with resistance from the tar inside. Just a working theory for now. Link to comment Share on other sites More sharing options...
SoCalManche Posted May 7, 2020 Author Share Posted May 7, 2020 1 minute ago, eaglescout526 said: Very well could've been. Still need to figure out this fuel problem. So pump constantly running with 12V applied and relay in place, it kinda wants to start but it acts like its not getting enough fuel to meet the demand of starting. Sound right? So I wonder if power loss is at that bulk head met with resistance from the tar inside. Just a working theory for now. Yes. Regardless if fuel pump was connected directly at 12V via second battery, or connected through harness on normal setup (which hits 3-4V on crank), the engine acts like it wants to FIRE without pouring fuel in TBI, yet it will not catch and actually fire. Link to comment Share on other sites More sharing options...
