Starting up my thread for my Comanche build. As it sits today, its a 1992, 4.0L, 5Sp, 2wd, SWB, Dana 35 that runs and drives fine with a few small issues. Overall, looking to make it go anywhere and be able to daily drive if needed. Currently, its being used off and on for quick rides/errands.
History:
Bought it from @kryptronic last fall
Installed 2 new tires, changed oiled and trans fluid to get ready for inspection
Passed PA inspection with the addition of license plate lights (the only one i didnt check)
Picked up a 99 Donor with a blown engine for the start of the 97+ swap (4wd, 5sp, dana 30 and dana 35)
Fixed a power steering leak
Bought a (supposedly) XJ Dana 44 rear axle with what the seller thinks were 4.56 gears and no mounts for $100
Sold to a jeep aficionado here just south of Pittsburgh.
Current Issues:
Damp Floorboard (need to investigate more)
Some weather stripping is rough
Multiple Dents/Dings (especially in the bed)
Windows are rough to roll down
Plans:
97+ Conversion (interior and exterior)
Onboard Air
Air lockers possible axle shaft upgrades
Determine gearing (will depend on lift/axles)
SOA Rear
Front lift (3 Link, 4 Link?)
Steering Upgrades
Bumpers, rock sliders, bed rack, bed sliders?
Lighting upgrade (LED or halogen, adding fogs)
Tires/Wheels
Paint/body panel fix
Frame stiffeners?
Engine Rebuild/Stroker/LS Swap TBD
Pic Dump (a few from the day i brought it home and of the parts jeep):
27 minutes ago, krustyballer16 said:
O i bet that was fun backing your jt with the dolley into Nick's driveway! Ha.
I can help you with the rock sliders and bed sliders! And bumper possibly too.
Sent from my SM-G973U using Tapatalk
That actually went much easier than expected, and 1000x easier than getting the cherokee loaded. The front tires on it were completely flat and held 0 air, so we figured that slowly backing the dolly under would be our best bet. the truck got about 2/3rds of the way up the ramp before the trailer came off the hitch and punctured the tailgate. Luckily Uhaul covered the damage, but still a pain to deal with
  • 3 weeks later...
Was mowing the lawn yesterday and noticed a small puddle under the comanche, looks like I'm leaking coolant near the passenger headlight. I'm hoping its a loose fitting/bad hose, otherwise I'll need to replace the radiator or start the full teardown (which i planning on starting after i got the cherokee torn apart).
There is also a drain plug on the radiator on the bottom passenger side. You can get to it through the front of the wheel well. I had that leak on mine.
  • 1 month later...
Well, the project budget took a hit today. Managed to get two flats in the gladiator with my multiple trips to Lowes and Home Depot while building a deck, so decided to upgrade when replacing those tires. Hoping to look into the raidiator leak next week. (it hasnt been bad, but definitely needs to be looked at soon)
Thanks for this tip! Took a quick look while i was outside yesterday and was able to tighten this down and stop the leak. Got the system burped and its ready to go again.
