Exhaust Manifold Heater Hose Connector
I know many of you have removed your worn out pre-heater hose from your exhaust manifold to your airbox due to deterioration. And I have not really seen anyone yet with a long lasting viable replacement of the factory hose, so my question is, has anybody plugged and/or capped the connector coming off the exhaust manifold?
6 minutes ago, JustEmptyEveryPocket said:
Why would you? Its not open to the exhaust. The "pipe" you see coming off the manifold is just formed by thin metal wrapped around the exhaust header. I guess you could cut it off if you really think it would be a problem....
True..........just annoying and a bit OCD I guess.
it´s just a jacket, it forces air to come in contact with the hot manifold and sends it to the air box, this is not exhaust gasses...
i use it to heat air, suck that air throught the LPG vaporizer and then send that air to the manifold...
