cbrant Posted March 15, 2020 Share Posted March 15, 2020 1992 Jeep Comanche Long Bed 4.0 I6 / Automatic/ 4WD / Front axle ??)/ Rear axle (???) / LWB Build date: Current Location: Des Moines, Iowa, USA bought it from Chillicothe, MO. Status: Running well, awaiting a garage so I can start restoration/modification. It has rust in the rockers and cab corners and likely under the rear flares. Frame and everything is in good shape, but dirty. Notes: 113,000 original miles... Burgundy exterior and gray interior. Cloth bench, column shift. Current owner: Long time Jeep owner. First car was a '99 TJ, then an '04 LJ, '12 Patriot, and my brother has had a couple XJs and a TJ. Always wanted a Comanche and finally found one. Hoping to find some replacement rockers and cab corners. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 16, 2020 Share Posted March 16, 2020 Check your VIN again for me please. can't get it to come up and the last eight run as an XJ. Link to comment Share on other sites More sharing options...
cbrant Posted March 16, 2020 Author Share Posted March 16, 2020 5 minutes ago, eaglescout526 said: Check your VIN again for me please. can't get it to come up and the last eight run as an XJ. Try it now. I am not sure if they are supposed to be "I"s or "1"s to be honest... Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 16, 2020 Share Posted March 16, 2020 It is a one, you are correct. Oh! I see the problem swap your three and six with each other. *C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -SA Charcoal 152 Zone 52-Kansas City 1AA U.S. Dealer Retail 26C Customer Preferred Package 26C 2TC Customer Preferred Package 2TC 3VN Customer Preferred Discount 4EA Sold Vehicle 4HC Special Scheduling Condition III ALA SE Decor Group APA Monotone Paint BAR 90 Amp Alternator BCD 500 Amp Maintenance Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KE8 STRIPE/BADGE/MOLDING/DELETE KWR STRIPE/BADGE/MOLDING/COLOR LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires TZA Goodyear Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV build date 9/26/91 Body code JL62 Link to comment Share on other sites More sharing options...
cbrant Posted March 16, 2020 Author Share Posted March 16, 2020 2 minutes ago, eaglescout526 said: It is a one, you are correct. Oh! I see the problem swap your three and six with each other. *C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -SA Charcoal 152 Zone 52-Kansas City 1AA U.S. Dealer Retail 26C Customer Preferred Package 26C 2TC Customer Preferred Package 2TC 3VN Customer Preferred Discount 4EA Sold Vehicle 4HC Special Scheduling Condition III ALA SE Decor Group APA Monotone Paint BAR 90 Amp Alternator BCD 500 Amp Maintenance Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KE8 STRIPE/BADGE/MOLDING/DELETE KWR STRIPE/BADGE/MOLDING/COLOR LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires TZA Goodyear Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV build date 9/26/91 Body code JL62 Thanks for figuring that out - appreciate the build sheet! Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 16, 2020 Share Posted March 16, 2020 No problem! Remember don't take it for full face value. Some codes are wrong like you don't have 265/60r18 tires. Link to comment Share on other sites More sharing options...
89 MJ Posted March 16, 2020 Share Posted March 16, 2020 6 hours ago, cbrant said: 04 LJ Still have it? Link to comment Share on other sites More sharing options...
cbrant Posted March 16, 2020 Author Share Posted March 16, 2020 1 minute ago, 89 MJ said: Still have it? No but I wish I did. It was my favorite vehicle I've ever had. Sold it because I was commuting an hour each way then moved really close six months later. Link to comment Share on other sites More sharing options...
Pete M Posted March 16, 2020 Share Posted March 16, 2020 1 hour ago, eaglescout526 said: No problem! Remember don't take it for full face value. Some codes are wrong like you don't have 265/60r18 tires. nor the SE Decor Group that's a late model XJ thing if I remember right. Link to comment Share on other sites More sharing options...
cbrant Posted March 17, 2020 Author Share Posted March 17, 2020 So what are the MMs for the axles representing? Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 17, 2020 Share Posted March 17, 2020 230 is the D30. 175 should be the D35. I don't know why but its Chryslers newest thing to have the axles in MM rather than their model. If you had a D44 it would actually say which is one of the few codes that Chrysler still uses. Link to comment Share on other sites More sharing options...
cbrant Posted March 17, 2020 Author Share Posted March 17, 2020 1 minute ago, eaglescout526 said: 230 is the D30. 175 should be the D35. I don't know why but its Chryslers newest thing to have the axles in MM rather than their model. If you had a D44 it would actually say which is one of the few codes that Chrysler still uses. Thanks man! They're so ashamed of the D35 they renamed it 😂 Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 17, 2020 Share Posted March 17, 2020 Lol. I am not sure why to 175 though? I would think the D35 is bigger than the 30 in size. Link to comment Share on other sites More sharing options...
jdog Posted January 31, 2021 Share Posted January 31, 2021 Selling Dealer: MIDPARK CHRYSLER JEEP INC Dallas, TX Link to comment Share on other sites More sharing options...
