2.5 renix no electric
  • Replies 103
Ok so I removed the correct switch this time, I'm on b3 with 12v. Whats the next step...i got my ignition switch off with ease when I removed the lower dash, the only thing that doesnt look correct to me is g1 peg, it looks really dark/burnt, but all wires and plastic look fine.
At the IGN SW connectors, jump C268_B3 to C267_I1. Measure for voltage at D1_2.
That one of three way the brake light finds ground (G1 is bulb check during crank).
17 hours ago, BoneheadJeeper said:
Ok re verified, d1-5 was hot. Nothing at d1-2.
Anybody have any idea? Relays, or anything like that come into play on this?
Missed your response yesterday. Not paying attention.
jdog got the next step:
10 hours ago, jdog said:
nothing at d1-2 with key on or off? did it have the jumper? if still nothing with key on or jumper check for power at the ignition control module, c2 yellow wire
C213_A (YEL)
Nothing when jumped/key on or off.
Is this the c2 wire? If so i have key on, and nothing going to it or coming from the wire.
Yes
As long as C267 and C268 are reconnected at the IGN SW.
