Reproduction switch trim covers
I’m working on recreating the dash bezel overlay for different switch options. As we all know, the cargo light and sport bar light options are almost impossible to find in good condition. I am wanting to see if someone can measure all the dimensions for the switch (see picture below). Need to identify overall dimensions, switch location and backlight location. The plan is to recreate them identically to the original with functional backlit logos for the different functions. My MJ is in the paint shop so I don’t have access to my switch panel.
  • Replies 59
To be clear, I am planning to recreate just the thin plastic overlay that has the switch icons and the on/off symbols. If anyone is interested any getting one please let me know. I plan on recreating the oem fog & cargo light to the left of the column and the transmission and sport bar lights to the right of the column. According to my research the sport bar lights has the icon shown below and is not the same icon as the fog lights
13 minutes ago, High2by said:
If this is something that you could do, I would be interested in a set. I had thought of trying to make this myself like Little Reds panel.
Sounds good. Just need to get the dimensions so I can get to work on them
I have this one. It is currently off of the truck and would be pretty easy for me to measure up. Please get me a list of the measurements you want and I'll be happy to do it for you.
9 hours ago, ghetdjc320 said:
Thanks! Need the width, height, distance from the top to the switch opening, distance from the top to the illuminated symbol, spacing between the switches. Basically everything that would be needed to recreated it on a piece of paper to scale. I have a couple of different plastic films I was planning to try to get the texture right. Its seems like the original is a semi translucent this sheet of flexible plastic that is painted black on the back side and uses a stencil for the symbol. Thanks for your help with this project!
I have the switch panels but don’t have access to them right now since my MJ is getting a full paint and body work job done. I’ll have it back in about 2 weeks so I can get the dimensions myself if needed. Just wanted to start working on it in the mean time. I should be able to create any option available if you can send me the pictures of the symbol needed. All of our MJs have the same 4 switch pods so it should be a fairly easy process to make for any of them. My only challenge was finding the right material but I have it narrowed down to a couple now. Will see which works best
Ok all, here is an update. Upon further investigation, the actual switch label is made of thin semi translucent plastic that has been textured on one side. The back side is smooth and that is the side that is painted. The symbols are simple not painted and the light reflects through it. The simplest way I can see to do this is to get a die cut black vinyl with the corresponding on/off and the symbol for the device. I will then transfer that vinyl decal until the smooth back of .03” thick textured hdpe sheeting which is durable and flexible. I have ordered the hdpe material and will work on vector tracing the oem switch cover to create the vinyl cut. The vinyl will also prevent the light transmission from anywhere but backlit symbol.
Once I’m happy with the final proof I’ll post the file for anyone to cut their own vinyl just like I did with the “Comanche” emblems I worked on. I am making this open source to make this accessible for everyone. I will post a brief write up on how this works when the plastic arrives.
Just now, eaglescout526 said:
I approve of how accurate that is.
Thanks! Next I’ll work on creating the vinyl to apply to the translucent hdpe to create the end product. If that turns out as the original then you can consider the trim cover back in production. As long as the logo is similar in size we should be able to do almost any variation and have it be backlit
