I finally installed my Scarfab trailer hitch
I finally got around to installing my Scarfab hitch. Thank you Brandon Scarbrough for this extremely well made hitch. It fit perfectly. But I do have a few issues that have nothing to do with the hitch.
First off, my truck was originally rear bumper delete. And evidently this means that they don't tap the holes for the bumper with threads. I started trying to tap the first hole, and was having issues keeping it straight doing it in the tight confines under the bed. Long story short, I broke the tap off in the hole. That stopped my work on it Saturday after work. So off to Lowe's to buy a new tap... I got two just in case.
So today after work I started again. The new tap has a larger square drive on its end that ended up fitting perfectly into a 9mm socket, that I then put on an air wratchet. The remaining holes were done in 2-3 minutes with that setup. And the hitch installed no problem. I'll have to deal with the broken tap later though.
My next issue has to do with the XJ Cherokee rear bumper I installed years ago. I have interference issues with the hitch and the bottom of the bumper. It looks like I should be able to just cut a couple notches in the bumper and be good, maybe add some spacers to the bumper mount. I'll figure it out, but it's just taking a little longer than I thought. Again at no fault of the hitch.
Here are some pictures. The first one is hard to see, but it shows the smooth bore untapped holes.
Thats a bummer. If you can get at it with a striking device of some sort you should be able to crack and crumble it out of the hole. Good forearm/ arm workout in there for you. Good luck.
Can you post a photo with the cherokee bumper installed when you get it figured out? I'd be curious what it looks like with the hitch mount.
I will do that. I'm curious myself as well.
As for the tap, I'm thinking I'll remove the spare tire, drill a hole in the frame rail opposite the weld nut and try to punch it out from the backside. Then I'll tap the hole and install the last bolt
4 minutes ago, dasbulliwagen said:
They are Bilstein 5100's that were originally speced for a rear lift on a Ram 1500. I have no idea what the part number is for them. Sorry.IMG_20181207_172721436.jpg.4c8dce75220eaff7d3f50232c9181108.jpgIMG_20181207_172648327.jpg.aa288da2344a9b002e2f34af20c62428.jpgIMG_20181207_172658843.jpg.7e77d1a20e28fab3881321569b41656a.jpg
Upside down.
And put a few coats of clear on those or they'll look like S in no time.
17 minutes ago, Big Dan said:
Is that Bilstein only or do you, personally, always mount the shock body towards the frame?
The bottom of his boots, now at the top of his shocks, have drain holes at the eyelet.
5100 series are mounted body up, boot down.
Many of us just take the boot off-
My next set don't even come with boots-
Also note,  his labels are upside down.
Tracking.  What I'm asking (as I'm ignorant on this) is, are all shocks meant to be mounted that way or is that Bilstein specific?  IE - a different brand of shock could be intended to be mounted shock body towards to ground.
As far as I know........higher end shocks such as Fox, King, and others are body up.
5100s are at the bottom of the high-end shocks.
I've never heard of this before. I'll have to look into if it makes a difference or not. I have them on the front too. Ones that are made specifically for XJ/MJ lift. There's only one way to install those, body down. So I guess I assumed that the rear would be the same way.IMG_20180818_110141260.jpg.69acbb31021eca20ddbc98c7285da1a7.jpg
Yep, fronts only.
Bilstein lists nothing on their site but is has been discussed just about everywhere.
Listen through the first 1 minute-
