89 MJ Posted January 3, 2020 Share Posted January 3, 2020 The 1st MJOTM of the New Decade: EvilMJ's 1989 Evil MJ!!! YEAR/MODEL: 1989 Jeep Comanche - 162k ENGINE/PERFORMANCE: 4.0L inline rebuilt at 145k DRIVETRAIN: 4.10 gears front & rear AX15 transmission w/ 115k on it at 145k Rebuilt 231 transfer case HD slip-yoke eliminator & Novak cable shifter Rebuilt front axle - new bearings, seals, U-joints, & ball joints Tru-track locker in front axle Clayton Offroad front truss Carolina Driveline rear driveshaft Rebuilt Ford 8.8" rear w/ disc brakes, new calipers, rotors, lines, etc. New clutch, flywheel, master & slave, pressure plate, lines, & bushing ELECTRICAL/IGNITION: New coil wires, distributor, and ignition module SUSPENSION/STEERING: Clayton Offroad 3-link long arm kit, trackbar, drop bracket, dropped pitman arm, & steering stabilizer HD steering linkage (draglink & tie rods) and diff covers New coil springs w/ adjustable spacers Bilstein shocks INTERIOR: Gentex auto dimming mirror w/ temp & compass JW Speakers BRAKES: Rear Disc LIGHTING: LED lights all around including A-pillars EXTERIOR: Custom bobbed bed, bumpers, sliders, 35" spare tire carrier, winch mounts, etc. WHEELS/TIRES: 5 Procomp 15s with 35x12.50R15 Pitbull Rockers MISCELLANEOUS: New fuel lines, pump, tank, & filter Spectre cowl intake and filter New exhaust, radiator, thermostat, Congratulations!!!! The bed on your truck is sweet! Link to comment Share on other sites More sharing options...
BeaterComanche86 Posted January 3, 2020 Share Posted January 3, 2020 I appreciate the time and thought that went into fabricating that bed. Really enjoy the way the spare pokes through the bottom. Nice MJ and congrats Link to comment Share on other sites More sharing options...
89 MJ Posted January 3, 2020 Author Share Posted January 3, 2020 31 minutes ago, BeaterComanche86 said: Really enjoy the way the spare pokes through the bottom. Me too! Link to comment Share on other sites More sharing options...
Pete M Posted January 3, 2020 Share Posted January 3, 2020 b-e-a-u-t-i-f-u-l! I have that same mirror! Link to comment Share on other sites More sharing options...
EvilMJ Posted January 3, 2020 Share Posted January 3, 2020 When I first got it, I wondered why he didn't put it on the outside of the bed, but once you see how far down it goes in the well, it would stick up well above the cab! It does keep everything compact and low when out in the woods. Link to comment Share on other sites More sharing options...
EvilMJ Posted January 3, 2020 Share Posted January 3, 2020 6 minutes ago, Pete M said: b-e-a-u-t-i-f-u-l! I have that same mirror! I am very happy with the mirror install. It was easy, has nice features, and its considerably larger than the factory mirror. Link to comment Share on other sites More sharing options...
89 MJ Posted January 3, 2020 Author Share Posted January 3, 2020 7 minutes ago, EvilMJ said: I am very happy with the mirror install. It was easy, has nice features, and its considerably larger than the factory mirror. Do you have a link to it? Link to comment Share on other sites More sharing options...
JMO413 Posted January 4, 2020 Share Posted January 4, 2020 Congratulations that is an awesome truck! Link to comment Share on other sites More sharing options...
NHMJXJ Posted January 4, 2020 Share Posted January 4, 2020 Outstanding build! Even if you bought it. It represents! Link to comment Share on other sites More sharing options...
EvilMJ Posted January 6, 2020 Share Posted January 6, 2020 On 1/3/2020 at 3:39 PM, 89 MJ said: Do you have a link to it? This is the same kit I bought, but for $79: https://www.ebay.com/itm/Gentex-261-Auto-Dimming-Mirror-Kit-w-Compass-Temperature-Wiring-Sensor-Cover/283733100676?epid=694317240&hash=item420fcf8884:g:2E0AAOSw3ydVopkq If you look up Gentex and mirror, you will see a bunch of them starting as low as $40. Some are just mirrors, some are kits. Options are autodimming, compass, and temp - be careful and order what you want. They may even come with map lights, but I'm not positive. Link to comment Share on other sites More sharing options...
EvilMJ Posted January 6, 2020 Share Posted January 6, 2020 Thanks everyone! I'm really happy with it. I'm in it at a great price, its dependable, and I think I can make money off of it if I ever decide to sell it (which I probably will not). Unlike most of the Comanches I looked at, it's not going to be a project - I already have enough of them! I can add something here or there, but I won't have to be working on it all the time. Link to comment Share on other sites More sharing options...
