1J7FT66LIKL547105
tugboat95
Bought 89 Comanche.  No rust anywhere.  108k miles.  4.0 engine.  2wd, 5 speed. Immaculate interior.  I think it's an Eliminator, but not sure what makes it one.  No decals or evidence it had them.  Also is it the Peugot tranny or Asin?
*Q7 Cloth Low-Back Bucket Seats
-SA Charcoal
167 Zone 67-Charlotte
1AA U.S. Dealer Retail
5AS Dodge City Tracking
5KR Midland Corporation
ADA Light Group
ALR GTS Interior Package
APA Monotone Paint
BA1 100 AMP ALTERNATOR
BCY BATTERY, 58-475 CC
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CAC Low Back Bucket Seats
CDB Reclining Front Seats
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
CUF Full Length Floor Console
DBB All Manual Transmissions
DDX 5-Speed HD Manual Transmission
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GNB Driver Side Illuminated Sun Visor
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAA Instrument Panel
JAY DO NOT USE - See JP, KA classes
JBD BEZEL-I/PANEL CLUSTER - BRIGHT
JCA 85 MPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
JKB MOPAR Hood Lock
K2B STRIPE/BADGE/MOLDING/COLOR
K3R STRIPE/BADGE/MOLDING/COLOR
KLH
LAF Seat Belt Alert-Driver Seat only
LAJ Headlamps On Warning Chimes
LAP Shift Indicator Warning Lamp
LBB Courtesy Lamps
LBC Glove Box Lamp
LBD Ash Tray Lamp
LBE IP LED Ambient Light Pipe
LCJ DOME/READING LAMP B-PILLAR
LDH U/Hood, Removable/Rechargeable Lamp
LHD Headlamp Off Time Delay
LMA Halogen Headlamps
LNJ Front Fog Lamps
LPE Cargo Lamp
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MCA Rear Body Color Applique
MDA Front License Plate Bracket
MFK Body Color Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF2 18.5 Gallon Fuel Tank
PE4 COLORADO RED PRIMARY PAINT - HE4
QE4 COLORADO RED SECONDARY PAINT - HE4
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TAD HIGHWAY TREAD
TBC Compact Spare Tire
TBM Tire Carrier Winch
TRM P225/75R16 BSW On/Off Road Tires
WJH 15X7 Aluminum Wheels
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGB 1 Additional Gallons of Gas
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z59 Left Front Spring Group Ix
Z78 Right Front Spring Group VIII
Build date 3/6/89
Body code TS61
Quote
Build date 3/6/89
awww... :(  that would indicate a Peugeot (from the factory).  the AX-15 came in on March 10.
you should post up in tech asking if it's an Eliminator.  hopefully somebody will spot something that wasn't available on a well optioned Pioneer.  :dunno:  Either way it's a sweet truck! :L:
18 minutes ago, eaglescout526 said:
The parts manuals actually decode each digit of the VIN better than the digital parts catalogue program. I don't have an 89 catalogue but JMO has them and get tell which VIN means what.
It is an Eliminator. 6th digit is a 6.
From the paper parts catalog.
excellent :D  I was thinking the body colored parts and the silver strip on the rubber side trim would indicate that, but the rims were throwing me for a loop.  The truck would have come with the 10 hole rims from the factory.
also your grille is upside down. :L:
That's great info!! Thanks a lot. Except for the added AC, this Jeep is exactly like the one my Dad had when I was learning how drive. That's why I bought it. It was an Eliminator but with different rims. Gonna double check the tranny as I have found out the slight visual differences. However I'm currently out of state, so it will be a bit before I can do that. It's just as fun to drive now as it was 30 years ago.
Sent from my Moto Z (2) using Tapatalk
  • 1 year later...
