Ken Nelson Posted December 11, 2019 Posted December 11, 2019 While driving off road engine stalls or has no power. Mechanic suggested to replace the fuel pump and sending unit. I find the fuel pump, but cannot find the sending unit. Any suggestions?
87MJTIM Posted December 11, 2019 Posted December 11, 2019 Sending units are no longer available. You will have to reuse your old one.
eaglescout526 Posted December 11, 2019 Posted December 11, 2019 26 minutes ago, 87MJTIM said: Sending units are no longer available. You will have to reuse your old one. That’s not entirely true. There’s the MTS ones JMO used but got mixed results.
Pete M Posted December 11, 2019 Posted December 11, 2019 Does it drive ok on the roads? what specifically is the truck doing when it falters? welcome to the club! you should put your truck's specs in your signature.
JMO413 Posted December 11, 2019 Posted December 11, 2019 MTS does make a fuel sender that does work. The only issue is the level sensor is not accurate. MTS phone number 1-800-522-1622
Red Mistress Posted December 12, 2019 Posted December 12, 2019 There is several NOS MJ fuel sending units on eBay. i would verify part #’s before buying.
