WanderingAccountant Posted December 4, 2019 Share Posted December 4, 2019 Hi all, first post here. I’ve owned a 1989 Comanche, manual straight 6 cylinder 4.0, since December 2018 and have done a significant amount of repairs. Regarding this specific question: I’ve recently had the engine rebuilt, the clutch, master, and slave all replaced, and a new exhaust and catalytic converter installed (as recently as today). Last week, I noticed a low rattle when starting the truck, that eventually goes away and comes back intermittently. Additionally, I’ve noticed a loud grinding rattle/clanking at higher RPMs (can’t say what RPM due to not having a tachometer). I have googled for days, and paid north of $7K for the above repairs, and related repairs, such as new spark plugs, hoses, etc. I am running out of patience (and money!). Please help! Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 4, 2019 Share Posted December 4, 2019 What kind of shape is all the rubber in? Motor mounts and suspension rubber. I don't know if that is your answer but it is a place to start checking. Having any of the rubber mounts and stuff worn out can lead to stuff like you describe. Someone else might chime in to give an idea to check. Link to comment Share on other sites More sharing options...
Dzimm Posted December 4, 2019 Share Posted December 4, 2019 I'd take it to where the work was done and have them give it a look. If it wasn't doing it before then it would be something that was installed or worked on more than likely. Link to comment Share on other sites More sharing options...
WanderingAccountant Posted December 4, 2019 Author Share Posted December 4, 2019 Thank you all for the replies. I’ve uploaded a sound clip of the noise to help anyone assess. This is in neutral, pressing the accelerator with the microphone held near the shifter. Comanche Noise.m4a Link to comment Share on other sites More sharing options...
yxmj Posted December 4, 2019 Share Posted December 4, 2019 Is there a factory metal shield above the muffler? Link to comment Share on other sites More sharing options...
WanderingAccountant Posted December 4, 2019 Author Share Posted December 4, 2019 54 minutes ago, yxmj said: Is there a factory metal shield above the muffler? I just called the shop that replaced the catalytic converter/muffler and they say it’s all good and tight down there. 11 hours ago, Dzimm said: I'd take it to where the work was done and have them give it a look. If it wasn't doing it before then it would be something that was installed or worked on more than likely. Taking it in to the shop that did the engine work tomorrow morning for a look. Link to comment Share on other sites More sharing options...
omega_rugal Posted December 4, 2019 Share Posted December 4, 2019 is there vibration when the sound comes up? Link to comment Share on other sites More sharing options...
yxmj Posted December 5, 2019 Share Posted December 5, 2019 So what was the diagnosis? Link to comment Share on other sites More sharing options...
WanderingAccountant Posted December 6, 2019 Author Share Posted December 6, 2019 On 12/5/2019 at 4:35 PM, yxmj said: So what was the diagnosis? Shop called today, ended up being a clutch bearing! They will drop the transmission and fix at no charge. Thank you all! I’ll report back on if it’s fixed next week! Link to comment Share on other sites More sharing options...
