Double din install
I’ve been tossing around the idea of moding the dash for a double din head unit. Used to have one in my TJ and really enjoyed some of the features (especially a backup cam). Most of the pictures I saw involved moving the hvac controls down and deleting the center vent. However, as has been noted, the center vent is attached to the plenum and if I moved the hvac controls there it would not seal the plenum back up. I would also loose the center vent and I actually really like that vent. So instead I decided to move the hvac controls to the top and move the radio to the center. I plan on running a Sony CarPlay headunit like the ax1000 which has a single din frame but a double din screen. I’ll post pics on how I will install this setup. I plan to retain the center vent as well but move it down about 1/2”. Should be a good clean oem looking mod when done.
5 hours ago, TexanEliminator said:
Following. This is looking great! I’ve been scratching my head how to fit a double din in mine.
Thanks! Just waiting on the equipment now for the install. Going to mount the backup cam to the tailgate if i can get it to look clean enough.
Here are the final results. Everything works excellent and the center vent blows plenty of air. Plenty of trimming needed but all in all not to bad. I did not need to widen the opening for this head unit so I have about a 1/8” gap but it looks just fine and very clean.
there are plenty of license plate mounts available if it doesn't pan out. :L:
  • 4 months later...
