500 MJ Posted October 10, 2019 Share Posted October 10, 2019 1992 Jeep Comanche 4.0 / AX-15 / NP 231 / D30 / D35 / LWB Build Date: ? Current Location: Fredonia, WI Status: Junkyard, “X” on windshield, about to be crushed. Notes: All parts worth picking are gone. Tail lights, rear bumper, gas tank, HO items from engine, rear slider are all removed. Bed, rockers and cab corners are shot. Over 200K miles, I moved the speedo cluster and center console to another Jeep in case it does get crushed. Neither part in great shape, but they were there. Gray interior. Hit hard in the front, t-boned a telephone pole. Current owner: APR (Auto Parts & Recycling) Link to comment Share on other sites More sharing options...
Pete M Posted October 10, 2019 Share Posted October 10, 2019 bench with headrests!! Link to comment Share on other sites More sharing options...
500 MJ Posted October 10, 2019 Author Share Posted October 10, 2019 Correct, gray cloth bench and it was in good shape too... Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 11, 2019 Share Posted October 11, 2019 Those vents on the side where the covers used to be are worth snagging. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 11, 2019 Share Posted October 11, 2019 *C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -SA Charcoal 155 Zone 55-Milwaukee 1AA U.S. Dealer Retail 25C Customer Preferred Package 25C 2TC Customer Preferred Package 2TC 3VN Customer Preferred Discount ALA SE Decor Group APA Monotone Paint BAP 75 Amp Alternator BCC Dual 730 Amp Maint Free Batteries BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KER KWR STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires TZA Goodyear Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build Date:9/10/91 Body Code:JL62 Link to comment Share on other sites More sharing options...
Pete M Posted October 11, 2019 Share Posted October 11, 2019 56 minutes ago, 500 MJ said: Correct, gray cloth bench and it was in good shape too... you should have grabbed it. Link to comment Share on other sites More sharing options...
500 MJ Posted October 11, 2019 Author Share Posted October 11, 2019 I’ve got to go back to that area later this fall and I could try to get them then. The bench seat might be a tough one to fit for the ride home. Might just go for the cover and the bottom foam if the foam is in good shape... this is about 2 hours from my home, so planned trips for work and lunch hours in the yard are how I get there... Link to comment Share on other sites More sharing options...
Pete M Posted October 11, 2019 Share Posted October 11, 2019 I haven't yet gotten to modifying my own headrestless bench into having headrests (using the back frame from a later seat) so while I want to say grab the whole back frame, I'm not yet 100% that it'll bolt to earlier benches. not yet at least. maybe when I get back from florida. Link to comment Share on other sites More sharing options...
Pete M Posted October 11, 2019 Share Posted October 11, 2019 also rear flares Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 11, 2019 Share Posted October 11, 2019 Never mind Link to comment Share on other sites More sharing options...
500 MJ Posted January 16, 2020 Author Share Posted January 16, 2020 I located some older photos of this truck from 2016 when I first found it. Posting them up for reference. Also, I have not been back to this yard since I made the original post in October, no idea if this truck still exists or not... Link to comment Share on other sites More sharing options...
jdog Posted January 31, 2021 Share Posted January 31, 2021 Selling Dealer: SHOEDER'S AUTO CENTER INC Rhinelander, WI Link to comment Share on other sites More sharing options...
