I love this jeep! going to be a long rd to recovery. It has a cracked frame in the reat but aquired another pair of jeeps who need help.  So I have my work cut out for me
The black one has the broken frame.  I have repairdd thr ignition system and brakes.  I stopped really hard one day and the leafspring mount on the rear drivers side busted.   The driveshaft fell out as well.  I jakced it up put the shaft back in and refilled the fluid.  I found some ratchet straps and three quarter inch cable and strappped it back together.  ......
Now it has a small whole in the top of the radiator somewhere.... And the water pump might be foing out.
The red one aka kicking wing needs some work.   I originnally stumbled across it when i was suppose to go hiking... It jas all the parts TuttuT needed..... But he is pretty much a work truck.  The frame is in amazing shape but the floor is gone on the driver side.  On the positive side someone has already gone through the trouble oftaking out the interior.  But had to gwt it towed to a friends bc 4 jeeps is two too many
The Jeep gods have been kind to me!!!!  The third MJ is in good condition but needs just a few things to be road ready.  I fixed the colymn shifter link on it and POWWOW... Fired right up.  Theses comanches are tricky but seems pretty basic when it co es to fixing them.   It has the speing swap done too the rear.... Not sure wheter to swap it back or lift the front.... Also need to work on the steeri g column.  I thinkthe previous owner installed an automatic trans and put in 4×4....
Well...lighting is something to be desired. Well it seems like you have good chunk of work cut out for ya. Trucks look nice though, shame one was owned by Fred Flintstone.
Be sure to register them and you'll get a build date and build sheet!
I'm guessing the lens is dirty?  or maybe the phone case's window?
awesome trucks though.  I've got no doubt you'll give them all the attention they need. :D   they just need more steel thrown at 'em.
rusty trucks need lovin' too!  :comanche:
  • 5 months later...
I am going to get some better pictures.   But do t know if i have the time to fix these two ... But am faced with a leak maybr from the top of the radiator.... Not sure.
My other Comanche had the rear speing swapped over axel..... I am wo dering is it ok deive like that or doea the front nees lifted or rear need dropped
5 minutes ago, 89 MJ said:
How high do you want to go?
Just to make it level.  I got it already raised in the back and it didnt run.  I i tended to use it for parts. But   The transmission cable was loose and fixed it.  Now it ru s... Not well yet but a matter of time.
You can pick up lift pucks (1.75 in) pretty cheap usually.
what components do you have now?
also, clean your lens. :L:   at least that's what I'm assuming is causing the fuzziness of the photos. :dunno:
