mark corbitt Posted September 7, 2019 Share Posted September 7, 2019 My new MJ project has the wench, tube,etc, bot the wire hanher has only a frayed end. I wenched it down and it seems to be long enough, but I need the piece on the end of the wire that holds up the spare when I crank it up. Anyone have one or a suggestion on a remedy? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 7, 2019 Share Posted September 7, 2019 Pretty much any tire winch will have that same piece , go to a junkyard if you have one and look until you find one that will go through the center hole of the wheel you are using Link to comment Share on other sites More sharing options...
mark corbitt Posted September 7, 2019 Author Share Posted September 7, 2019 thanks for the advice, but I would like an original one if anyone has one. Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 7, 2019 Share Posted September 7, 2019 24 minutes ago, mark corbitt said: thanks for the advice, but I would like an original one if anyone has one. It has almost gotten to the point where you will have to rebuild your old winch or use the brackets and adapt one of the “big three’s” winches to the MJ bracket. I did that. Link to comment Share on other sites More sharing options...
mark corbitt Posted September 7, 2019 Author Share Posted September 7, 2019 37 minutes ago, eaglescout526 said: It has almost gotten to the point where you will have to rebuild your old winch or use the brackets and adapt one of the “big three’s” winches to the MJ bracket. I did that. The winch works fine, I just need the piece that attaches to the cable that passes through the wheel and holds it up. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 8, 2019 Share Posted September 8, 2019 Maybe I wasn't clear in my first post . I'm not saying to use the entire winch just the end piece you're looking for . Here's a picture of an s-10 winch you can harvest the end piece off of and the Comanche winch side by side to show what difference there is Link to comment Share on other sites More sharing options...
schardein Posted September 8, 2019 Share Posted September 8, 2019 I think the piece that actually holds the tire/wheel assembly can be sourced from any vehicle with an under body tire mount, as others have said. Understand that you want an original, hope you find one. Bigger question (in my mind) is once you have that piece (original or not), how do retain it on the old cable? First post says you have nothing but a frayed end. Link to comment Share on other sites More sharing options...
kansashogan Posted September 8, 2019 Share Posted September 8, 2019 Yea, I would be hesitant to put a new end on unless you have a way to crimp the piece that goes on the cable. I would hate to see it come off driving down the road. I think I have a good one if you are interested. Let me check tomorrow. Link to comment Share on other sites More sharing options...
mark corbitt Posted September 8, 2019 Author Share Posted September 8, 2019 Thanks for the input and advice, I was thinking I would run the cable through or around the part that passes through the rim and double it up and secure it with a couple of cable"ties" Link to comment Share on other sites More sharing options...
mark corbitt Posted September 8, 2019 Author Share Posted September 8, 2019 36 minutes ago, kansashogan said: Yea, I would be hesitant to put a new end on unless you have a way to crimp the piece that goes on the cable. I would hate to see it come off driving down the road. I think I have a good one if you are interested. Let me check tomorrow. Please let me know, thanks. Link to comment Share on other sites More sharing options...
kansashogan Posted September 8, 2019 Share Posted September 8, 2019 Mark, I do have one in good shape. Goes up and down as it should. How about $45 shipped? Link to comment Share on other sites More sharing options...
mark corbitt Posted September 9, 2019 Author Share Posted September 9, 2019 I will let you know, I called a local yard and they have a mj so I am going to look at it in the next day or two Link to comment Share on other sites More sharing options...
mark corbitt Posted September 15, 2019 Author Share Posted September 15, 2019 Thanks Kansashogan, I found one locally. Link to comment Share on other sites More sharing options...
