I never intended to make a thread about this Jeep but figured now I should as I'm doing way more work on it than I ever intended.
Bought it maybe 3yrs ago (don't remember for sure) with broken motor mount bolts but ran decent with new rad.  Doors and main body was in okay shape but rockers and floors were rusted.  Some PO put steel down for new floors but it rusted away since they put the carpet back down and didn't paint it.
Got Midas to remove broken motor mount bolts and put new ones in, day of, on a Saturday for $100! I also replaced the leaking vacuum lines so I got a halfway decent for Iowa, running driving XJ for $950ish total.
Deer hit the driver's side on my way to work about a week after buying it and dented both doors.  At that point I decided it was a beater and minimal work and money would be put into it.  Shortly after the water pump died but luckily I had a spare used one and just made a gasket with a Manilla folder so it cost me nothing.
Had to rebuild the t-case last year because the chain went slack and was slipping and slapping the case.  Not a hard job at all but the more I worked on little things here and there, the more I realized how poorly maintained this Jeep was.  Installed a new radiator in February (I think) of this year because it started leaking.
Pictures will come eventually of previous stuff but some of it is in my MJ threads already.
This Jeep really only gets driven in winter because it developed a misfire and started running rich.  Did some testing over a year ago and found cylinder 3 to have low compression but kept driving it anyway.  Initial testing on that also told me it was a valve issue (no longer seems that way).  This year I moved it a few times and it was really rough.  Sounds terrible and used to billow white smoke so I decided it was time to do something.
I ordered a new O2 sensor and PCV valves for it to try and fix the running rich condition.  The O2 sensor went in with no issue.  I also got a can of Restore because I was going to try it for the low compression but when I pulled the PCVs out I found chocolate milk in the valve cover.  Pulled the oil cap to find the same thing and the dipstick read way high and was all milk.  Ran to Napa, got some oil and did a change and let it run some of the crap out but decided it was time to tear the motor apart.
Found the new rad I put in 6ish months ago to be leaking in the dead center with no apparent damage so I'm going to see if they can send me a replacement.
As for the motor, the valve cover was held on with basically 4 bolts, the rest were only hand tight, explaining why everything was covered in oil.  The head is removed and it appears to have been a headgasket leak into cylinder 3 and maybe a little into 4.  There is a carbon ridge but it's not terrible, and the cylinders still have the markings in them so that's good.  Going to order seals, check for bent pushrods, clean it up, and put it all back together and hope for the best.
Also don't EVER use Stop Leak.  The coolant passages in the headgasket were completely blocked by it.  Thought I had flushed that all out after I bought it but obviously not.
I never expected to find this.  Literally no coolant could flow through the block at all because the crap in the head gasket was rock hard.  Very glad it didn't blow up on me.
Welp I guess I won't be getting it put back together this weekend.  Cleaned the block off and was cleaning the head and found a crack between cylinder 3 and 4 where the gasket leak was.  It runs from the head bolt hole, all the way down to the coolant jacket on the the opposite side.  It doesn't actually go into the cylinder area but comes really close.
I'm calling a salvage place in MN tomorrow about a used one they have listed for $80 with 105k miles on it and a 90 day warranty.  I was hoping to do a reman but the cheapest I could find would be $350 after core return and shipping from Rock Auto.  I'm not sure I trust the head from "Famous Brand" given I can't find anything about them online.  Price isn't bad but I'd rather use that money to get tires for the red truck..  O'Reilly's was the next cheapest at $400 after core but not tax.
Cylinder head showed up the other day.  Today I got it hauled out to the shop and looked over a little before work.  Hopefully I will get time before work tomorrow or Sunday to get it cleaned and installed.
Also decided to try something new.  Rather than doing a million pictures of everything, I'm going to do shortish videos to kind of track the progress on it.  There will still be pictures but probably not as many.
This is an overview of the Jeep as well as where I'm at with it.
2 hours ago, JMO413 said:
Like the video. I laughed s little when you said the seat feel through the floor. Mine did the same thing on my XJ.
Thanks!  Yeah I got a good laugh out of it too when it happened.
Not sure what happened but it ended up with a dead spot in the beginning of the video but it gets the point across regardless.  Basically the video covers going over the cleaning of the replacement cylinder head.   This is also from like a week ago.  Little behind on stuff.
  • 4 weeks later...
This is from a month ago.  I wasn't sure if I wanted to finish this video or not because I was having all kinds of issues with it.  I finished it anyway, its not great but I want to keep track of the work done on this so I felt it needs to be done.  I will definitely make the next ones better.
  • 1 year later...
Well turns out I never finished editing and uploading the last video... I've got too much going on to do that right now but I finished up the head install and drove it for about a year without issue.
The end of last summer I was out at the farm doing some work and went to turn around in the ditch and heard some popping in the front end and some not so nice noises.. turned out my front u-joints were so beyond rusted that the needle bearings were fused together or completely crushed into powder on both sides.  What was a simple u-joint replacement turned into a bunch of work that has been going on since the end of last summer, I'll go through it briefly.
Replaced the u-joints, then figured I'd do the ball joints since I was in there, also ended up doing new hubs, and new sway bar links.
I also decided to paint the front grill and headlight surrounds.  Had to replace one of the surrounds because one was broken.  Looks great now, just need to paint the bumper to match.
I then discovered that my rear spring mounts were much worse than they previously were.  I had made some repairs to the floor in that area but it wasn't great.  I finally decided since the front was completely rebuilt, I'd do the rear too.
I got some ironman off-road rear shackle boxes because mine were starting to rust and were flimsy.  They take some work to install but are great.  They've got 8 bolts holding them in to the frame, floor, and rear brace and they can be welded.  I also rebuilt the rear springs with an extra main that I cut the eyes off of to fix the sag.  With the modified springs, ironman shackle mounts, and ironman shackles I ended up with about 1.5" over stock lift in the rear.
Idk why but a couple pictures turned upside down when I upload to CC, not sure what's going on there..
The driver side is completely done including a 1/4" thick piece of angle iron I ran front to back to fix the floor seam.  That needs more welding but it's good enough for right now.
I cutout and replaced the floor pans over the front spring mounts again and got them welded good to the mount and surrounding metal so it should be just as strong as it was originally.  Need to go back through and seal up all the seams so it doesn't start rusting again.
The passenger I just have to assemble the spring, drill the holes to mount the shackle box, then assemble it all.  The floor seem isn't destroyed yet on this side so it's not getting angle iron.  Grease the shackles, get the taillights, rear bumper, and hitch back in and it'll be back on the road!  Still more sheet metal work to do, namely the rear quarters and have to reassemble the interior but I can at least start it up and move it for the first time in like 8 months her soon.
there's some sort of glitch that we haven't figured out yet. :dunno:   something in the softwares that is out of our league.  but we do know that if you alter the image (like rotate and then rotate back) and save it, then upload, it'll be correct every time. :L:
  • 5 weeks later...
Well I started putting the super old videos together to finish out most of the work that was done between then and now.  Didn't think I would do the videos again but here we are..
