Parts to grab from a two door
jdog
The switch panels are useful and tough to find, probably the 2-dr wiring harness as well. I can't say whether the regulators or motors will be worth it, don't know that they're the same as the 4-dr stuff for the MJ.
Otherwise its all the usual 2-dr stuff that works on an MJ... Tilt seats?
- Even if the upholstery is junk, the seat frames can still be combined with Brandon's or OEM MJ floor pedestals and turned into MJ bucket seats of whatever variety you want.
- The switch panels are desirable and can be used for an MJ. They will require slight modifications to a ground tab if used with (I think) '91 or newer wiring, but that's not a huge deal.
- Interior parts
- 2.5L stuff if it is a 2.5L.
- If the original radio is still in it, there are a distinct group of people who would be interested in that. If it says "made in Korea" anywhere on it, it is junk and is not worth shipping cost.
- Gauge cluster can be used in another 84-86 XJ or MJ.
- Front grille parts if they are still present, including the 10 slot grille. Those can be used on trucks up to  and including 1990.
- Interior parts
I'll have to grab the frames, and switches then radio is aftermarket, grill is gone. Vehicles a v6
1988 swb 4.0 ax15 np 231 red with gray interior.
rear side windows if they are the vent kind
One side is broken, but I think there's one inside of the vehicle
